Reset button on DIC not responding
Teebee03
Year and Trim: 2003 SSEi
Post by Teebee03 »
This is a recurring problem on the wife's 2003 SSEi . Sometimes (becoming more often than not anymore) the reset button on the DIC won't reIset the function (ie tire pressure, gallons used, etc.). If I wait a while sometimes it will work or maybe not.
Is this problem common? I'm thinking the switch behind the button is in need of cleaning. Or is there another way to reset the tire pressure, gallons used, Avg MPG and oil change monitor? (Oil change, I think can be reset with gas pedal, right?)
If I were wanting to try and clean the switch under the button, does that little cover plate with the buttons pop out from the dash or does the dash cover have to come off first?
heather.christian83
Year and Trim: 2003 ale
Re: Reset button on DIC not responding
Post by heather.christian83 »
I have this problem as well. None of my buttons work though. My husband is wondering how to investigate and fix.
Teebee03
Post by Teebee03 »
Hopefully someone will be able to answer the questions.
heather.christian83
Mine turned out to be that the whole panel was unplugged. When the car lot worked on it they aid jot reconnect. Hope u get its figured out.
Teebee03
Post by Teebee03 »
I might check that out. I just wonder if I have to take the whole dash out or if the little panel will come out separately.
heather.christian83
We could not figure out how to get just the lil panel out...there may be a way though. Good luck
How to remove the dash bezel is included in this write-up: http://www.pontiacbonnevilleclub.com/fo ... =18&t=7188
The little panel will come out of the big piece once you have it removed. If it is plugged in, and its not working... I'd suggest trying a different one. PM me if interested.
heather.christian83
Thanks!
Teebee03
Post by Teebee03 »
Thanks for the reply....Sorry for the late response, been busy the last few days. I'll get to taking out the dash in the next few days and let you know what I find.
Teebee03
Post by Teebee03 »
Sorry, I forgot to post about the solution to my issue. With instructions from harofreak, I was able to remove the dash and get the DIC module out. I was able to take it apart to find how it works. I took electronic cleaner solution on the end of a q-tip and cleaned all the connection points. After putting the unit back together, I reinstalled the module, and tried it it working fine. I wish now I had taken some pictures to show what it looks like and what I did to clean the points. I will say that the end of the q-tip was black and grimey.
I hope that this helps someone else that is experiencing a similar problem.
