Sure, there are lots of posts in the archives but the last detailed parts numbers/ordering info is several years old.
AFAIK, there still is no kit availble- you have to buy each part individually off an internet retailer.
If a forum member has recently ordered the bushings/bolts/washers/retainers.
Could you please share the part numbers/prices and where you bought them.
Its kinda confusing to sort through the archive posts.
I'm tempted to go to the wrecker and see if a low mileage donor is available, that way I know all the parts are exactly right.
Thanks in advance......
Subframe Bushings- latest ordering info please. No kit avail
- Roadtech195
- Posts like an L36
- Year and Trim: 2007 Grand Prix GT
Re: Subframe Bushings- latest ordering info please. No kit a
Could you go to a dealership and have them look up the part# ?
I found these and they look similar...
http://www.1aauto.com/1A/BodyMounts/Pon ... 062/363553
A part # to varify would be nice.
If you want to take 1 out and get the dimensions... this place will have what you need and maybe something better.
http://www.energysuspensionparts.com/En ... lators.asp
2007 Grand Prix GT L32
Poly endlinks, swaybar bushings and dogbone bushings. Drop in high flow air filter. Its a start!
2009 Mitsubishi Eclipse GS (project BlackSheep) Bone stock for now, 5 spd and fun as hell! (Gf's Ride)
1996 Pontiac Bonneville SE Gone but not forgotten
1997 Dodge Ram Sport 4x4 5.9L The Beast!
- reb
- Posts like an LG3
- Year and Trim: 1997 Bonneville SE 40th Ann Edition
Original Owner - Location: Wantagh, NY
Most of the online retailers do not have the retainer bolts in stock.
Shopgmparts.com appears to be the best source at this time for all the parts at a reasonable price.
- Roadtech195
- Posts like an L36
I sure wish you luck in finding the things you need. I will keep looking when I get some spare time.
glenn304bonne97
- Year and Trim: 1997 bonneville se
im having the same problem let me know if you figure it out
[img][/img]
- reb
- Posts like an LG3
I was able to use the Dorman "Kit" to replace the lower/upper insulators spacer and retainer in position #2 (center-rear). The kit is a steal @ $25.00 each kit. Purchased 2 kits to do the job and had a pair of lower insulators left over.
http://www.dormanproducts.com/gsearch.a ... q=14103535
The included bolt is not the right size. The original bolt has been redesigned and has a new part #11561577, which I purchased at a local GM dealer.
