Carbon fiber vinyl wrap, update pg 2 3-13-13
crash93ssei
Post by crash93ssei »
Updated from this topic - viewtopic.php?f=7&t=32547
Got the wrap today, also got out of work early so I thought I would try it out real quick.
I am very impressed with this stuff, looks great and is quite easy to work with, just make sure you are very generous with a hair dryer when heating it up and take your time. This is the first time I have ever worked with covering something in vinyl and it took me about 20 minutes including running outside for a screwdriver and the bathroom for some rubbing alcohol to clean up the bezel.
Bezel before. Boring, gray, we all have them.... blah :lol:
3M 1080 Scotchprint black carbon fiber vinyl
20 minutes later
Installed in the '03 SSEi
I REALLY like the look and can't wait to do the rest of the parts :) I am sure that after a few get done and I really get my technique down I will be able to do one of these vents in about 10 minutes or less :beerchug:
Thoughts? Like, dislike? Constructive criticism?
01bonneSC
Year and Trim: 05 Chevy 'Hoe
89 SkiDoo
Re: Carbon fiber vinyl wrap, with pics!
Post by 01bonneSC »
Is there heat involved? Looks good how you can see the open/close molds through it.
yourgrandma
Year and Trim: '02 SSEi
Post by yourgrandma »
Looks way better than I thought it would. Is it very hard to wrap it around the compound curves?
Must be a lot thinner than the stuff I used, considering you can see the vent mode bump out things behind it.
crash93ssei
It definitely isn't thin, it would be near impossible to work with on this bezel without heat from a blow dryer or heat gun. I let the blow dryer on high on the flow indicators for about ten seconds then pressed it pretty hard and held it to make sure they showed through.
With heat applied it is actually very easy to work with and wrap around tight spots.
It looks amazing! Did you think about spraying a layer of clear coat over it to give it a shinier appearance? To be honest though, I can't decide if it looks better flat-ish, or glossy like the GXP stuff.
SSEiMan01
Post by SSEiMan01 »
Looks good! Also kinda trippy. I like it though!
James May wrote:Hello.
crash93ssei
nos4blood70 wrote:It looks amazing! Did you think about spraying a layer of clear coat over it to give it a shinier appearance? To be honest though, I can't decide if it looks better flat-ish, or glossy like the GXP stuff.
I have thought about it, unsure at this point as to if I will try it or not though.
Do them all, then take a scrap, apply it to something, clear it, and decide what you like better. That way you don't "ruin" the vent.
crash93ssei
Not worried at all about ruining a vent, if I don't like it I can just remove the vinyl ;)
I have a complete extra set right now that I will sell when I am done if anyone is interested.
BonneMe
Post by BonneMe »
That looks very good, awesome work! Definitely a service you'll be able to offer with detailing :wink:
I think clear coat really wouldn't be smooth enough on the textured surface. I've read online where clear coat crushes the detail/texture of it.
http://www.carbonfiberfilm.com/blog/exp ... ng-di-noc/
Heat gun on low is muuuuuuch faster than a hair dryer on high, but depending on the curves your're working with, it might not be necessary, and you have to be careful.
I've been considering this for a while in my car to darken the light grey interior, and even got a 1'x2' sheet of this stuff to try it out as it was only $5 and I wanted to wrap part of a phone.
http://www.amazon.com/gp/product/B005BT ... 03_s00_i00
I haven't heard of the 1080 yet, but it sounds like it's better for curvier surfaces?
crash93ssei
BonneMe wrote:That looks very good, awesome work! Definitely a service you'll be able to offer with detailing :wink:
Actually even the blow dryer on high made quick work of heating the vinyl enough to make it very workable without issue.
Definitely give the stuff you got a try, I can't say either way if it would be better or worse for curves, but I do know that without heat applied there is absolutely no way I could have gotten it to take shape like this.
yonkerse
Post by yonkerse »
Looks much better than expected Ryan! I figured that would be a real PITA but you seemed to prove its not!
Eric
A few mods..
crash93ssei
I will have a write up for it soon, finishing the last vent right now ;)
Dark_Knight
Year and Trim: 1996 Bonneville SE
Post by Dark_Knight »
I like the way it looks! I did the same thing to both of my visors actually! since they were sagging bad and i didnt want to waste money just replacing them :)
It's not who I am underneath, but what I do, that defines me.
Dark_Knight
-More Pics Here-
http://s1065.beta.photobucket.com/user/ ... r/library/
crash93ssei
Got three sample packs of vinyl from 3M today, each pack includes a 3"x5" sample of every style and color available in their 1080 Scotchprint lineup. Some colors are WAY out there, but some are REALLY nice! The metallic colors especially look really good!
Blown93SSEi
Year and Trim: Dark Green 1997 SSEi
Post by Blown93SSEi »
Looks great! I can't wait to save up the $$ and get this done!
Jacob, Dark Green 1997 SSEi "The Green Lantern" Over 268,000 Miles and Still Going Strong!
Mods/Stuff: INTENSE! FWI, ScanGauge 2, Mobil 1 HM Oil, Valvoline HM Transmission Fluid, Mildly Tuned PCM, Drilled 180 Thermostat, Cleared Corners, Silverstars, Chrome T-Stars, NGK Iridium Plugs, NAPA Belden Wires.
yourgrandma
I want to try the brushed steel.
jreigner
Post by jreigner »
In addition to my 01 ssei, i have an 87 fiero gt which I wrapped in the 3M 1080 matte black vinyl. it was super easy to work with. For compound curves you must use primer 94 or it will lift up in any heat. I surmise this will happen to the venting as soon as it is cold and heat passes through it or the dash reaches 200+ deg. in the summer. Cool idea though. :)
crash93ssei
jreigner wrote:In addition to my 01 ssei, i have an 87 fiero gt which I wrapped in the 3M 1080 matte black vinyl. it was super easy to work with. For compound curves you must use primer 94 or it will lift up in any heat. I surmise this will happen to the venting as soon as it is cold and heat passes through it or the dash reaches 200+ deg. in the summer. Cool idea though. :)
Already had one in the freezer for an hour then pulled it out and hit it with my heat gun until it was basically hot enough to burn me, no peeling issues at all. I made sure to leave enough to wrap around the back side just in case because I was worried about that possibility to begin with.
Jerry (RepinS) his girlfriend Liz, my fiance Heather and I went out to my dads boat last night, he has a Rinker 320 EC and the entire dash is plastic woodgrain. It looks very classy, but doesn't really fit with the rest of the boat... Needless to say at the end of the night I took home the center section of his steering wheel to do some work on, after about two hours and ruining two pieces of vinyl attempting to make it work, I finally got it. I am sure the rest of the wood grain will be covered in this as well :beerchug:
