Window guide clips for power windows
jimbone_sdca
Year and Trim: 1991 Bonneville LE
Post by jimbone_sdca »
Have been trying to locate guide clips for all the power windows on 91 le none of the dorman or other brands work and dealer here in san diego said you have to order replacement windows as they don't sell the clips separately. I am sure you could order clips separately if I had part numbers for clips. I found this to be true of other parts. You can't trust Dealer parts dept here in San Diego cause they tend to be A BIT CROOKED. Anyones help would be apreciated as I Inherited this car and have been restoring it but because the guide clips on all the windows are nonfunctional you canbt roll them down at all or they will fall into the doors. Thanks for your time! :helpsmilie:
burger
Year and Trim: 1997 Pontiac Bonneville se
Re: Window guide clips for power windows
Post by burger »
If there's a body shop you trust you could see if they could get the parts for you
97 Bonneville se-Winter car
85 Yamaha xj700-Summer cruiser
murderedout
Year and Trim: 1989 bonneville LE flat black paint 133k
Post by murderedout »
junkyard?
I had to get mine from a dealer a couple years ago and they had to order them. I will look when I get home and look at the part number on the invoice.
purplexj
Year and Trim: 1990 Olds 88
1999 Regal GS
Post by purplexj »
I think you can get those on rockauto, couple bucks ea. They are just plastic pieces. I would not trust junkyard ones though.
