Code 22 and code 23 car dies at idle
- murderedout
- Year and Trim: 1989 bonneville LE flat black paint 133k
i just changed the cps on my 89 and drove it for ten minutes. Let it idle in the driveway and it just shuts off? i checked for codes and it came up with 22 and 23 car will not start until it cools off, but temperature gauge is fine.
- J Wikoff
- Year and Trim: 1992 SSE
Re: Code 22 and code 23 car dies at idle
Did you make sure the new CPS is well aligned? I don't think the TPS or IAT signals are enough to make the car stall/not start.
- murderedout
Yeah its aligned. It wouldnt run right if it want right? I did some pretty aggressive driving after I installed it and it was fine. Its when I got back twice from driving it I sat in the car running for about 5 minutes and it just turns off. No rough idle or anything just out of the blue shuts off. Actually last night I was turning down my street off throttle before I had done the new cps and it died, luckily I coasted home
It has to be heat related.
