sunroof spoilet/deflector
- whtiger4229
- Year and Trim: 2000 SLE
Does anybody have one of these on their bonnes? I'm thinking of trying one to limit the air noise when I have my sunroof open a little bit. I've seen them on other cars but not on any bonnes yet so not sure how it would look.
"if everything seems under control youre not going fast enough"-Mario Andretti
- leatherneck
- SSE Member
- Year and Trim: 2002 SLE
Re: sunroof spoilet/deflector
Mine has one that pops up just enough when the Sunroof is opened... I hav played with it at speed before and it makes a difference. I find that if you get buffetting at speed then pop open a rear windo about 1/2 inch and it goes away.
2002 Bonneville SLE 128k miles aka "Frankenbonnie"
Intense PCM w/2004 improved trans shift points/180 fans-stat/+3deg timing advance/DTC inhibit
Transmission Cooler
Upcoming changes - Hi Flow Cat/Exhaust - Cold Air Kit
1993 GMC 'Burb aka "Zombie Assault Vehicle" 230k miles
Transmission Cooler
