Passenger Side Rear Window Cable Not Working
Posted: Sun Mar 25, 2012 11:50 am
I have the interior panel off, and have disconnected the window from the slide, but I can't get the window out to find where the upper cable (engine side) attaches to the slider.
The slider is still attached to the lower cable (trunk side) but I have no idea where the upper cable goes. It is buried up in the top of the door, and at this point is either jammed or covered up by the window.
If you know how to get the window out, that would be a help. If you know how this window system works and could provide some guidance on fixing it, that would be even better.
Thanks in advance,
Kevin
Thanks in advance,
Kevin
