Passenger Side Rear Window Cable Not Working
kstills
Year and Trim: 2001 SSEi
Post by kstills »
I have the interior panel off, and have disconnected the window from the slide, but I can't get the window out to find where the upper cable (engine side) attaches to the slider.
The slider is still attached to the lower cable (trunk side) but I have no idea where the upper cable goes. It is buried up in the top of the door, and at this point is either jammed or covered up by the window.
If you know how to get the window out, that would be a help. If you know how this window system works and could provide some guidance on fixing it, that would be even better.
Thanks in advance,
Kevin
kstills
Re: Passenger Side Rear Window Cable Not Working
Post by kstills »
Alrighty, I pulled out the slider assembly (upper cable pulled out of it's slot) and I'm putting it back together.
Any ideas on how the cable is wound around that lower pulley?
Archon
Post by Archon »
The cable wrap in opposite directions, so that as one cable is pulled in, the other is let out. Perhaps, this will help. http://www.pontiacbonnevilleclub.com/fo ... f=43&t=212
kstills
Post by kstills »
Archon wrote:The cable wrap in opposite directions, so that as one cable is pulled in, the other is let out. Perhaps, this will help. http://www.pontiacbonnevilleclub.com/fo ... f=43&t=212
Doh!....
Not sure how I missed that when I searched for getting the door panel off...
Thanks for the link, I did figure out most of that myself yesterday.
Seems that my cable and gear are pretty beat up, and when I managed the 'fix' of putting the top cable end into the slot where the spring for the lower cable goes (it worked), the cables were getting boogered up inside the gear mechanism.
I was able to get the window to stay in the 'up' position, so the car is now drivable, but I'm pretty sure I'll need a new regulator in order to fix the cable issue.
fritcr
Year and Trim: 2000 SE
Post by fritcr »
Check with harofreak I just bought one for mine with the same issue from him. He has good prices.
Rob
2000 Pontiac Bonneville SE Silver on Black Leather (Silver Streak) -144k
2003 Chevy Silverado LS Blue over Graphite (Old Blue) -184k
2001 Pontiac Montana Ext White over Tan Leather (Man Van) -wifes car -142k
1998 Pontiac Grand Prix GT Coupe Gray over Graphite (not named yet) -daughters car -157k
1996 Chevy Camaro RS 3800 Red over Graphite (Zoltan) -sons car -145k
