location of the crank position sensor please 97 grand prixSE
Talk about the other 3800 powered GM cars, particularly for items not covered in other sections that may be unique to your year/model, and differ from a Bonneville.
razmatazz
Year and Trim: 1996 pontiac bonneville se
Post by razmatazz »
so iam going through the elimination process to determine a hick up problem i am having. i have eliminated the possibility of a fuel pump, battery and alternator are new, all grounds are good. so now iam going between the MAF and CPS. ive sprayed the MAF with cleaner and looking to find and replace the CPS can any one tell me were it is located. ive seen online that it is either located underneath the exhaust or behind the harmonic balance. does any one know for sure.
http://i1190.photobucket.com/albums/z447/razmatazz1/Untitled-1.jpg
PLAGUE PHANTOM
Re: location of the crank position sensor please 97 grand pr
Post by PLAGUE PHANTOM »
You will need to remove the harmonic balancer. You should see a connector when it is off
