Check Engine codes?
iRoll4z
Year and Trim: 2001 ssei bonneville
Check Engine codes?
Post by iRoll4z »
can you guys point me in the right direction of exactly how to get these 3 codes fixed?
*PO171
*PO449
*PO742
also, i replaced the camshaft sensor and changed 3 motor mounts but i still need to do a solid mount on the front.
iRoll4z
Re: Check Engine codes?
Post by iRoll4z »
also, my mph and rpms gauges do not work all of a sudden. what can be the problem?
dpnewfie
Post by dpnewfie »
iRoll4z wrote:can you guys point me in the right direction of exactly how to get these 3 codes fixed?
*PO171
*PO449
*PO742
P0171 - lean bank one (vacuum leak)
P0449 - Evap vent solenoid needs replacing
P0742 - Torque Convertor clutch circuit stuck on.
J Wikoff wrote:It has been an honor and privilage to have been serviced by you.
2005 Bonneville GXP, 200k and SOLD!
