2002 bnneville will not start
- samples08
- Posts like an L36
- Year and Trim: 2002 SSEi
88,000k - Location: Piedmont South Carolina
curently stuck at work but anywho, got in car to start, drove her fine this morning, turn key all lights come on battery has charge and gas is good but when i turn key to start i get nothing any help greaty appericated !!
Member #3848
2002 Black Bonneville SE Sold But Not Forgotten
2002 White Bonneville SSEi Project car
- Mechanical Mike
- Retired Gearhead
- Year and Trim: 99 SSEi
- samples08
- Posts like an L36
Re: 2002 bnneville will not start
Starter is not making any noise
Member #3848
- Mechanical Mike
- Retired Gearhead
Sounds like the starter may be bad. You can try tapping on the starter while someone turns the key to the start position. If that doesn't help then you need to see if the small wire on the starter is getting 12 volts when the key is turned to the start position. If the small wire has 12 volts then change the starter.
2006 Chevy Monte Carlo SS
- harofreak00
What is the security light doing?
smittyingr
- Year and Trim: 2001 3.5 Aurora
You could have a full charge in the battery as far as volts but could have a problem with amps. Lift up your back seat and put a multi meter on the battery and have someone try to start it if the voltage drops below 9 volts when you are trying to start the engine then you do not have enough amps to turn the starter over and it is a bad battery. If the volts dont drop much at the battery when trying to start it then check voltage at the starter like said above.
- leatherneck
- SSE Member
- Year and Trim: 2002 SLE
I had a similar issue and found the wire on the starter solnoid had came off along with my wire...
2002 Bonneville SLE 128k miles aka "Frankenbonnie"
Intense PCM w/2004 improved trans shift points/180 fans-stat/+3deg timing advance/DTC inhibit
Transmission Cooler
Upcoming changes - Hi Flow Cat/Exhaust - Cold Air Kit
1993 GMC 'Burb aka "Zombie Assault Vehicle" 230k miles
Transmission Cooler
might want to look at the gear shifter switch, move the shifter as you are turning the key
