Cut apart factory Harness
Locked
myworld
Year and Trim: 1994 Bonneville SSE
Post by myworld »
My factory radio went out so looked to replace it and the wires was cut and put back together. Remind you the front and right and left speakers are out, and when i turn the key back for the radio the car shuts off its a 94 bonneville. any help with the rewiring colors. Need to get the speakers on and the radio on when the key is turned back
willwren
Re: Cut apart factory Harness
Post by willwren »
Locked for double-posting and posting in the wrong section. This one was moved from General Chat before I saw the other.
Do NOT double-post. It splits your replies and divides your responses into two topics that some might miss. Do not post mechanical or electrical problems in General Chat.
Locked
