Gas gauge
99bonnySe
- SE Member
- Year and Trim: 1999 pontiac bonneville Se
Gas gauge
my gas gauge always reads full and idk waht the problem is, when i turn the key to "on" it seems to be in the postion of how much has i have in it then it spikes to full when i start the car. also sometimes the gauge just goes to empty and i get a light "check gauges" any help would be appreciated
2005 monte carlo ss supercharged - speed daddy headers, cat+egr delete, gmpp 2.5 inch cat back, 3.4 pulley, custom tune, intake best et + mph 13.91@98.77 2.001 60ft
1999 bonneville se - winter rat
LeSabre in Buffalo
- Year and Trim: 2012 Eco
Re: Gas gauge
The sender is inaccurate, or there's a wiring problem somewhere. For the sender, you can get 2 cans of Chevron Techron Concentrate and add that to a full tank of gas. Then let the car sit for a weekend, and drive it to work and back. If the sender is fouled, that will clean up the sender. Otherwise, you'll have to replace the sender assembly. That's a PITA since the tank needs to be dropped.
99bonnySe
- SE Member
Re: Gas gauge
*dang* alright ill try that cause its hard to tell how much gas i have, that would be the sending unit that has to be replaced right?
Bob Dillon
- Retired Gearhead
Re: Gas gauge
Yup, sending unit. I used the cheap one from Rockauto, it was like $75 (versus >$300 for the factory part) and replaced it myself in about 3 hours. Two guys makes it a whole lot easier. A lift makes it easier still, but who has a lift?99bonnySe wrote:*dang* alright ill try that cause its hard to tell how much gas i have, that would be the sending unit that has to be replaced right?
If you decide to do it, buy the tank gasket with three prongs sticking downward from the dealer, maybe$10. I never could get the plain o-ring provided with the sending unit to seal.
