Day Time Running Lights
99bonnySe
- SE Member
- Year and Trim: 1999 pontiac bonneville Se
any kinda fuse i can pull so i can shut the lights off even when the car is in gear? thanks guys
2005 monte carlo ss supercharged - speed daddy headers, cat+egr delete, gmpp 2.5 inch cat back, 3.4 pulley, custom tune, intake best et + mph 13.91@98.77 2.001 60ft
1999 bonneville se - winter rat
LeSabre in Buffalo
- Year and Trim: 2012 Eco
Re: Day Time Running Lights
In the winter especially those DRL are helping other drivers to see you. Why disable a completely non-intrusive safety feature?
99bonnySe
- SE Member
just never liked em, they are disabled on my monte by just putting a cover over the indicator, just wondering if there is a way to do it
- 92BonneSE
- Posts like an L67
- Year and Trim: 2008 Aura XE
http://www.pontiacbonnevilleclub.com/fo ... 19&t=18705
Black Pearl wrote:You must pull the electrical connection from the DRL resistor. The resistor is found on the driver's front side of the engine bay. First, find the large black box which contains the computer. Next, pull the black box to the left so you can see the horn easier. Once you find the black horn, look to your right you will see a small white box thats bolted to the frame of the car. There will be a electrical connection on the back of the white box snap if off and your done. Once the connector is out of the white box you no longer have drls. The head lights will still turn on so there is no need to worry.
2017 Cruze RS
2008 Aura - Totaled
Sold but never forgotten:
1998 Bonneville SE
1992 Bonneville SE
99bonnySe
- SE Member
thanks a lot man!
