Turn signal problem
theax40
Year and Trim: '03 SSEi
Turn signal problem
Post by theax40 »
I replaced the signal and brake light bulbs in the rear, and now none of the signals work. The front signals are on all the time as DRLs, but they won't blink as signals and the rear signals don't blink at all. It looks like a wire running to the left signal got flattened a little by one of the posts on the back of the light housing when I screwed it back in. Could it just be a blown fuse? Or could the crushed wire have shorted out?
Chris
2003 SSEi|Galaxy Silver Metallic
Archon
Re: Turn signal problem
Post by Archon »
Did you change the wiring for the DRL to where it uses the filament for the turn signals in that bulb? If so, that could be your problem. Try removing that mod and see if they work properly, then.
theax40
Post by theax40 »
I'm not sure what you mean, but by DRL I mean the front signals are always on, and them blink for turns. But now, the front signals are lit up, but don't blink. The rear signals are always off and don't blink, not even with the hazard button pushed. There also are no green signal indicators in the gauges, no clicking to indicate turns signals either.
I've read another post with a similar problem, with getting the wire pinched while putting the rear assembly back on. But there aren't any exposed wires so I wanted to see if it could just be a fuse or something. Before i try to fix the wire.
Chris
theax40
Post by theax40 »
I'm just unsure if one shorted wire going to one blinker would cause all these different things to stop working; all blinkers, the green blinker arrows and the clicking that accompanies them. But I, admitedly, don't really know what I'm talking about so...
Chris
locowbl
Year and Trim: 2000 SE
Post by locowbl »
Check your fuse box's. The diagram in the lid will show you where the signal fuse is located. It would be real easy to varify visually once you remove the fuse and look through it If the strand is burned through in the middle then you know that is your problem. If you replace it and it blows again then check the wire. Even though it might not be cut into when you pinched itbetween the housing the strands on the inside could be broken.
LocoWBL
theax40
Post by theax40 »
Pulled the back seat, and the signal fuse was blown. Not sure if the flattened wire caused it or what. Replaced the fuse and I guess I'll just have to wait and see if it blows again.
Thanks for the help guys.
Chris
Gagger14
Year and Trim: 2010 Dodge Ram SLT Big Horn
1995 Chevy Camaro Z28
Post by Gagger14 »
I know this is a late reply, but I just recently had a similar issue with my turn signals. Kept changing the fuse, seemed to work, and then all of a sudden, they stopped working again. Never actually pinpointed the issue, but I'm about 95% sure that one of the wires got wet and caused a short... I would just check the fuse, the bulbs, and if it happens again, let it dry out. :beerchug:
In My Garage:
1995 Camaro Z28 - LT1 w/ 6-speed, Magnaflow Exhaust, Moroso Cold Air Inake, Powerstop drilled/slotted rotors and ceramic pads, Z06 Chrome Wheels, Founders Performance Strut Tower Brace (Work in Progress)
2010 Dodge Ram SLT Big Horn Edition Quad Cab - 5.7L Hemi, 390HP, 4x4, Daily Driver
Past Vehicles:
1989 Acura Legend - 'Tank'
1999 Dodge Dakota Ext. Cab - 'Bulldog'
2004 Bonneville GXP - 'Red Demon' - Already Missed
***Showed up expecting a battle, left with a laugh***
Spitzkindl
Year and Trim: 1994 Bonneville SSE
Post by Spitzkindl »
I had the same situation on my Trans Am 01. In this case the problem was a bad wire connection to the front DRL/turn signal light, which gave the exactly same result: turn signal didn't blink, but stayed steadlily on. After fixing the bad connection, I had the same situation when I didn't connect one of the two rear break/turnsignal bulbs (there are two on each side in a Trans Am). So you can get this problem if any of the wiring or bulbs related to any turn signal has a problem. Since you got the problem after chaing the rear bulb, I would check for the problem rear. Wrong type of bulb? Bad connection there? Don't forget to check for bad earth.
05joenov
Post by 05joenov »
Not sure if I should have started a new thread as this is the exact issue I'm having with my 05 GXP. I put LEDs in the brake lights (turns and reverse already had leds). I tested them and all were working fine. Put everything back together and washed the car...then nothing. Fuse was blown so I changed it out and it still blows it right away. Of course it is raining now so if it a wet wire it would be hard to check. I'll have to keep monitoring it looks like.
Gagger14 wrote:I know this is a late reply, but I just recently had a similar issue with my turn signals. Kept changing the fuse, seemed to work, and then all of a sudden, they stopped working again. Never actually pinpointed the issue, but I'm about 95% sure that one of the wires got wet and caused a short... I would just check the fuse, the bulbs, and if it happens again, let it dry out. :beerchug:
2016 GMC Sierra SLT
2005 Pontiac Bonneville GXP
1979 Pontiac Firebird Trans Am
theax40
Post by theax40 »
My problem turned out to just be a flattened wire, it may have cause a short but I haven't had any problems since. Check to see if a wire got pinched between the body of the car and the flat washer-type piece of metal that's on one of the screws that hold the taillight in place. When I tightened mine down the wire got pinched between them.
Chris
