I have a 2000 Bonneville SLE which we love. wonderful car. 164,000. The transmission is having problems, shutter delay pop to reverse and first some times. slight roar when accelerating. cruising. Pan has metal shavings. I found a complete 2002 SE Bonneville I was considering buying for parts to keep mine going. Will the transmissions swap? I have read about a lot of valve body differences,electronics, converter sizes. I am mechanically inclined. Just don't want to make a costly mistake. Any incite is greatly appreciated!
Thank you,
Michael
2000 SLE TRANSMISSION SWAP QUESTION 2002 SE donor
shipmanlights
- SE Member
- Year and Trim: 2000 SLE
2005 SLE
Last edited by shipmanlights on Wed Aug 24, 2011 1:56 pm, edited 3 times in total.
2000 SLE
2005 SLE
1980 Z28
1968 JAVELIN
1968 CUTLASS S
2005 SLE
1980 Z28
1968 JAVELIN
1968 CUTLASS S
01bonneSC
Re: 2000 SLE TRANSMISSION SWAP QUESTION 2002 SL donor
Do you mean SE Bonneville?
shipmanlights
- SE Member
2005 SLE
Re: 2000 SLE TRANSMISSION SWAP QUESTION 2002 SE donor
Yes SE donor
2000 SLE
2005 SLE
1980 Z28
1968 JAVELIN
1968 CUTLASS S
2005 SLE
1980 Z28
1968 JAVELIN
1968 CUTLASS S
I don't believe the transmission will swap. You'll have to find the transmission tags, which are on the rear of the transmission towards the passenger side visible from underneath, and see if the codes match.
- olblueeyesbonne
- Retired Moderator
- Year and Trim: 99 SSEi
01 SLE
02 GTP40th
02 SSEi
06 GP GT - Location: Sauk Centre, MN
All that matters is if the SE has the F83 transmission. If it does it will work.
If your 2000 has the early model year trans you will just have to undo the trans cooler line adapter that goe between the trans and the trans cooler lines and your trans cooler lines will thread right in.
Trust someone who's in the know and has put a 2002 Park Avenue transmission in a 1998 Regal.
DHP Powrtuner & Tech 2
1998 GTP Coupe
1999 SSEi 70k miles
2001 SLE
2002 GTP 40th Anniv Ed Coupe
1998 GTP Coupe
1999 SSEi 70k miles
2001 SLE
