dashlight/ instrument lights blown?
BFF_Larry
Year and Trim: 95 bonneville sse
Post by BFF_Larry »
My Bonneville dashlights won't turn on when the headlight switch is pulled half way or either fully out. My voltage gauge light, that I mounted under the radio , went out the same time the dash and the lights for the a/c controls did.
I checked the fuses. They are fine unless the pinch tabs are bent or not in full contact
Any ideas?
95 bonny sse WALLED.
-new build in progress-
Iraggi HO alt - 320 amp (added "sense" wire and 5k pot, 15.4v)
2 DC Level 5 18s
Cactus Sounds K12
4 runs of 1/0
14 batts.
Mtx 4244 and (2) kicker ix404
YouTube.com/user/pitchdarkshadow
Bing
Year and Trim: S
Re: dashlight/ instrument lights blown?
Post by Bing »
My guess would be the switch itself took a puke. Junkyard run or pay up the butt for new.
BFF_Larry
Post by BFF_Larry »
i should of pulled one out when i was up there Friday. dang.
now my display for the a/c, heat isn't showing when headlights are on...
2 DC Level 5 18s
Cactus Sounds K12
4 runs of 1/0
14 batts.
BFF_Larry
Post by BFF_Larry »
I checked all the bulbs in the instrument... None blown.
Replaced the headlight/ twilight part with one from a junk yard... Still working the same... Not instrument lights.
Oh I also replaced the entire instrument with one from a junkyard and no luck. Even the volt gauge light bulb is good but no power/ light.
I also just replaced the DIC with one tht was working.
2 DC Level 5 18s
Cactus Sounds K12
4 runs of 1/0
14 batts.
atom
Year and Trim: Pontiac Bonevvelle SSEi 3.8 1993 y.
Post by atom »
BFF_Larry wrote:I checked all the bulbs in the instrument... None blown.
check graund bus- pass and driver
check http://cgi.ebay.com/ebaymotors/97-BONNE ... 2c5e2cb6a0
http://forum.detroit.in.ua/download/fil ... &mode=view
BFF_Larry
Post by BFF_Larry »
That was one of the first things I checked for corrosion. The connections were clean and looked basically new..
Thanks though for the link to the switch. And for your post.
2 DC Level 5 18s
Cactus Sounds K12
4 runs of 1/0
14 batts.
