Battery Issue- 95 Series 1
tripscarcare95
Year and Trim: 1995 SSei
1987 GN 16K Original
Post by tripscarcare95 »
Hello Everyone
I am having an issue with my battery keeping charged. I had to jump start the car after it was parked in the garage. I did the old vehicle to vehicle jump start and the ol bonny fired right up. i drove the car for a few hours and stopped here and there and all was well. i parked the car again and it would not start again.
i pulled out the battery and took it to a local auto store to have the battery load tested. The battery is perfect.
Now were to begin
Bad ground
Alternator is original, but I did the magnetic wrench to it trick and the wrench stuck to the back side
Any thoughts?
Thanks
Re: Battery Issue- 95 Series 1
Post by Jrs3800 »
What Voltage and Amps did the battery test at as compared to the Batteries stated Amps?
And is the alternator putting out the power it should be?
michaelbsc
Year and Trim: 1995 SSE, 2001 Buick Park Avenue
Post by michaelbsc »
tripscarcare95 wrote:I am having an issue with my battery keeping charged. I had to jump start the car after it was parked in the garage. I did the old vehicle to vehicle jump start and the ol bonny fired right up. i drove the car for a few hours and stopped here and there and all was well. i parked the car again and it would not start again.
Now were to begin
Bad ground
I had the same problem, and it was the grounding. The guy I bought the car from had replaced the engine with one from a wreck. (Not sure what happened to the factory engine, but it's gone.)
Anyhow, after about 14-16 months I couldn't charge the battery. New alternator later it still didn't charge, and I found the ground lug rusty and not so tight. 3 minutes later it was fixed and has worked fine ever since.
YMMV. I'm no auto expert.
