Maybe this weekend.
SSEimatt93
Senior Moderator
Senior Moderator
Year and Trim: 2016 Scat pack
Maybe this weekend.
Post by SSEimatt93 »
Looks like the SSEi is due for another top end tear down.
Lower intake manifold is leaking coolant on the outside, drips down the transmission, and makes a bit of a mess.
SC coupler is shot, I've never had one of these wear out on me before, but I do know what it sounds like/feels like, and mine is definitally gone.
Might have to De-mote the G8 to the driveway and park the SSEi in the garage in the mean time to start tearing it down. Once I have all the gaskets/orings/sealent/sc oil/coolant/engine oil, I can do the entire job pretty easily in half a day with my air tools.
Can't really think of anything else I need to change while I am in there, only done it 3 times on this car...this time..going to use the good AC Delco LIM gaskets.
3.09's 8 Speed Auto
04 GTP
PossessedPower
Year and Trim: 1993 ssei,2000 chev venture LE,1990 Dodge d-150
Re: Maybe this weekend.
Post by PossessedPower »
SSEimatt93 wrote:Looks like the SSEi is due for another top end tear down.
If you want help let me know.
More dangerous then a fire in a nursing home..
SSEimatt93
Senior Moderator
Senior Moderator
Not lookin like this weekend. To much other stuff to take care of...maybe in the next few weeks..I hope
3.09's 8 Speed Auto
04 GTP
2000Silverbullet
Post by 2000Silverbullet »
Since I'll be bringing my tools to Alberta next few weeks, if we get run out of my daughter's house early we'll be knocking in your door looking for a place to sleep. I don't mind sleeping on AL7's if you don't mind me playing with your dipstick. :wink:
......but the dog better not like Italian flesh. 8-[
SSEimatt93
Senior Moderator
Senior Moderator
Hahaha, You won't need to sleep in a car. We've got a spare room in the basement with an attached full bathroom. Beer fridge is in the furnace room within stumbling distance. The dog might pose intrest in you for a few minutes, then he will go back to sleep for 14-16hours.
3.09's 8 Speed Auto
04 GTP
Post by Jrs3800 »
2000Silverbullet wrote:Since I'll be bringing my tools to Alberta next few weeks, if we get run out of my daughter's house early we'll be knocking in your door looking for a place to sleep. I don't mind sleeping on AL7's if you don't mind me playing with your dipstick. :wink:
Wow talk about an interesting mental picture... :eek2: LMAO
SSEimatt93
Senior Moderator
Senior Moderator
Well the parts FINALLY got here from Intense. Canada Postal strike...what a mess.
Got a start on it last night. Pulled it into my garage, aired up my compressor, got out my impact, adapters, sockets...and other misc tools. Started at 5:45pm, when the girlfriend got home at 7:20, I was putting my tools back away, had the following removed:
Alternator, STB, Alternator brakets, Throttle Body/Air intake, fuel rail, Supercharger, Thermostat and housing, and the lower intake manifold. Keep in mind I have not done this particular job in about 3.5 years, but..its kind of like riding a bike..once you've done it, you never forget how. I took some pics, will post later. At work right now with my new fuel rail (From Andrew..bought a LONG time ago and stored), LIM, and spare valve head cover are in the parts washer at work.
Hopefully make some headway tonight, got some clean up to do. Might try to take it to Red Deer this weekend (275 miles one way). After this, I need to chase down my HVAC problem.
3.09's 8 Speed Auto
04 GTP
2000Silverbullet
Gitter done Matt. Two weeks is plenty of time! :bwoohoo:
Sadden
1994 Bonneville SSEI
2006 Grand Prix GXP
Post by Sadden »
Alberta Meet.
:lurk:
:canada:
2000Silverbullet
Where were you three weeks ago when I was in Alberta?? :ballkick:
SSEimatt93
Senior Moderator
Senior Moderator
Well, the entire engine is back together. Every nut, bolt, washer, gasket and oring.
Key on, fuel pressure holds around 50, perfect, no leaks.
Now onto doing an oil change before start up. Drain the oil into my catch pan..pretty simple..done it lots..
Remove the oil filter...
hmm..wow thats on there tight....
45 MINUTES LATER WOW THAT THING IS REALLY *fook* ON THERE AND IS NOT COMING OFF!!!!
I tried my gator grip, gloves, ole screw driver through it...NOTHING...I'm borrowing a filter wrench from work today...gotta get it done!!!! I want it out of my garage tonight!!!
Couldn't believe it!
And YES, I lube the oring up before installing the filter, every single oil change..
3.09's 8 Speed Auto
04 GTP
2000Silverbullet
Impressively quick turn around Matt.
...only to be quashed by a seized filter!
Lefty loosey
Sadden
2006 Grand Prix GXP
Post by Sadden »
2000Silverbullet wrote:Where were you three weeks ago when I was in Alberta?? :ballkick:
In the bush working :/ (Camp for 2 weeks.... Absolute hell)
Visiting your daughter?
Whens she due?
wake
Post by wake »
she already popped :wink:
Matt! thats horrible to hear you went all that way and your being held up my a *dang* oil filter... #-o
2000Silverbullet
You must have it off by now....
C'mon Matt, you don't have an oil filter wrench?! That's like #3 of the things every good mechanic needs, right after Duct Tape and 911.
petraman
2013 Audi A4 6MT
Location: ............ Granville, Ohio/Erie, PA *WCBF '08 SURVIVOR* *NEBF '07 SURVIVOR*
Post by petraman »
Heh, even I have an oil filter wrench... :lol:
2000Silverbullet
Hey, give him a break guys! A Canadian oil filter wrench costs $150.
Matt's hands are strong enough normally to twist the head off a transvestite. :)
He's understandably under a lot of pressure right now......what with his change of life coming up.......
wake
Post by wake »
2000Silverbullet wrote:Matt's hands are strong enough normally to twist the head off a transvestite. :)
:laughing3:
i laughed harder than i should have at this :roll: :lol:
Sadden
2006 Grand Prix GXP
Post by Sadden »
Pound 2 scredrivers through it and then use a pinbar to push against the screwdrivers.
