Unlock Radio
voller1410
Year and Trim: 2000 Pontiac Bonneville SSEI, 2002 SLE
Unlock Radio
Post by voller1410 »
I got a parts car and i wanted to put the other radio in it but it says its locked how do you unlock them?
Re: Unlock Radio
Must be programmed by the dealer with the Tech2
Dads Toy
Year and Trim: 1996 Bonneville SE
Re: Unlock Radio
Post by Dads Toy »
Your kidding. So what is you get another factory radio for a JY. Would you still have to get the code from the dealer? It seems there shoudl be a fix for turning the code off.
harofreak00 wrote:Must be programmed by the dealer with the Tech2
Bonneville SE 3.8 V6, Modified Throttle Postion Sensor, Platimun Plugs, Kummo Touring tires.
Re: Unlock Radio
This only applies to 00+.
99 and older are self-programmable.
AJT2004
Re: Unlock Radio
Post by AJT2004 »
When you repair the lights on the radio in the 2000+, does the radio lock when you put it back in?
JG2000SE
Year and Trim: 2000 SE
Re: Unlock Radio
Post by JG2000SE »
If the radio is coming out of and going back in to the same car in 00+ it is programmed and knows that it is in the correct, or same, car. If you change from one car to another it will realize it is in a different car and lock itself until unlocked and re-programmed by the dealership scanner. It's a theft-deterrent feature. Call around several dealers because they all charge different amounts to unlock and reprogram, anywhere from $40 up to $99, and be ready to prove it is your radio and not stolen.
2000 Bonneville SE- Galaxy Silver Metallic - Gutted Air Box - K&N Filter - 20% Tint - 77k miles
voller1410
Re: Unlock Radio
thats ok i dont need it anymore i jsut switched out the face plates and replaced the bulbs that werent working it felt like that was a hell of alot easier
kemicala
Year and Trim: 1993 SLE
Re: Unlock Radio
Post by kemicala »
search google for unlock "delco theftlock radio". plenty of help to be found on this. actually i just did this this past weekend after i picked up another jy cd radio. the gist is, with the radio off your press 2 and 3 until 3 numbers appear. then you press am/fm to get another set of 3 numbers. then theres a number you call and you follow the prompts and enter the 6 numbers you got from the radio. i dont have the exact number to call right now but like i said, if you google it, the help is readily available. takes about 10 mins and no need to pay the dealer.
figured id just go find it:
http://www.mifbody.com/vbulletin/showth ... dio-system
and;
http://www.dieselplace.com/forum/showthread.php?t=40705
