fuse location
mckcuzzi
Year and Trim: 94 se
fuse location
Post by mckcuzzi »
where is my ac,relay and blower motor fuse exact location on a 94 bonneville se
Icebound
Year and Trim: 1994 SSE White Loaded
1997 SSE White Loaded
Re: fuse location
Post by Icebound »
I assume Manual controls??
The fuses/relays should be:
(I am referring to all locations "facing forward", cause thats what the book does)
Fuse 5D (under instrument panel, left side) 25amp for blower relay control
Fuse 3: 30amp, underhood. right bank (facing forward) supplies power to the blower
Blower Relay; same underhood, right bank (facing forward) 3rd relay (counting from the right facing forward)
Fuse 5: 15 amps, Relay center against the right wall under/behind the glove box. powers the compressor relay and compressor clutch.
AC compressor control relay... underhood right bank of relays, 1st one on far right (facing forward)
mckcuzzi
Re: fuse location
Post by mckcuzzi »
many thanx to u man
