By frankiegator at 2011-05-16
All wired up.
viewtopic.php?f=13&t=25794
Thats what I did. Just cut a hole in the rubber ran the wire and put some silicone around to seal it up, I didn't want to deal with trying to drill a hole, it looks a lot easier for you because you didnt have to deal with the airbag behind the glovebox.BFF_Larry wrote:dont mount it onto box.
put it on some rubber mounts/ washers to absorb vibrations.
and i like where u drilled for the power wire.
i just put it through the rubber housing on the passserger door where the speaker wires run through for the door.
