how to remove the rear deck lid
PossessedPower
Year and Trim: 1993 ssei,2000 chev venture LE,1990 Dodge d-150
Post by PossessedPower »
I was wondering if anyone could help me with the removal of the rear deck i want to clean it up and replace speakers.
I'll ask here so i do break anything.
More dangerous then a fire in a nursing home..
taylorman2004
Re: how to remove the rear deck lid
Post by taylorman2004 »
This is what harofreak00 told me for my 04 SE.
There are 4 clips on the back of the upper seat back than you can release with a long flat blade screwdriver, Just push down on them and they will pop out. Then use an 18mm socket to remove the bolts at the bottom. Remove seat section.
Use a pry tool to release the 2 push in retainers that hold the rear shelf in.
Remove the rear C-pillars.
Now you should be able to lift the rear shelf, and pull it out. There will be some foam that will be holding it in on the backside. Do your best not to destroy it, but it has to be torn to come out, poor design.
To remove the speakers, use a 7mm socket. The speakers are also glued in, so you will need to pry them out of their hole.
PossessedPower
i have a 93, are the speakers glued down too?
taylorman2004
It's possible that they are. Mine were not glued down at all and if they were the glue wore off but there was no evidence of any glue.
92BonneSE
Year and Trim: 2008 Aura XE
Post by 92BonneSE »
He is pretty spot on about steps for removing it. I don't remember any type of glue holding my speakers in only some screws, but I might of just pulled them out without noticing
2017 Cruze RS
2008 Aura - Totaled
Sold but never forgotten:
1998 Bonneville SE
1992 Bonneville SE
PossessedPower
92BonneSE wrote:He is pretty spot on about steps for removing it. I don't remember any type of glue holding my speakers in only some screws, but I might of just pulled them out without noticing
Do it right the first time and it costs less. lol
Never been good at undoing plastic clips
