2003 SSEi signal issue
- Toms94
- Year and Trim: 1992 SSEi (sold)
1996 SSE(sold)
2003 SSEi - Location: Kansas
On the trip to visit the daughter today I noticed the left turn signal is not working. Right signal is fine. When I turn it on the rear light glows...dimly, but glows. The front doesn't, I had a new bulb so I replaced it, still no love. Are there separate fuses for left and right side blinkers? Could a flasher be bad on just one side? Any suggestions?
- Year and Trim: .
Re: 2003 SSEi signal issue
Check all the bulbs including the front. There is only 1 fuse for both sets of blinkers.
- Toms94
1996 SSE(sold)
Ok, I have replaced both bulbs with new ones. Still the same. I don't think that I mentioned before that when I turn on the four way flashers, the right ones both work and the left doesn't. It does not even light them up on the dash. I also check the fuse, which was good obviously since the passenger side works. I always thought that when the bulb goes out and you turn the blinker on the light on the dash would burn solid.....not blink but would be on.
02ssei
- SSEi Member
- Year and Trim: 2002 pontiac bonneville ssei
when you say the left side glows dimly it makes me think the problem is a ground.
2002 Bonneville SSEI 170K
"Three men walking always has one teacher."
