No boost
All questions and problems regarding Superchargers, Turbos, NOS, ZEX, intercoolers, water injection, etc.
dave1003
Year and Trim: 1992 ssei
No boost
Post by dave1003 »
hey everyone...apreciate every thing you guys do
Let me start by saying i know nothing about bonnevilles or superchargers
some of you may have seen my car in pics and vids....I am a guy that would rather fish
than be fed...but, could use some help on this one.
i have a 92 ssei (the one with the ugly wheels lol)
*****at idle actuator is fully extended to full boost...lubed shaft with 3 and 1..
when opening the throttle hard the bca tries to retract to bypass
replaced cracked hardline to bca...turbo worked great for 1 night
next morning...no boost
pulled a 56 code off the history
test ohm resistence to the bcs..says OL(out of limit i assume)
when i unplug the bcs vacuum line coming from the supercharger or manifold (wichever)
the bca quickly retracts to bypass...
also ...i cannot find any vacuum leaks
I'm thinking bcs...what do guys thinkl
Re: No boost
Here is a good link to use:
http://www.3800supercharger.net/diagnosing.html
The next thing to check is the BCS (boost control solenoid). It'll be easier to check if you remove it from the BCA. Disconnect the electrical connector and remove the bolt(s). Once it's in your hand, use an Ohm Meter to check the resistance across the two pins. I've seen BCS readings vary from 500K ohms to 1.5M ohms. Anything in that range is good. If you get infinite resistance or a dead short (0 ohms), you'll need a new solenoid. These don't fail often, so getting one from a wrecker is a good option.
Thanks to Willwren of course.
Hey Bill, I borrowed a link from your siggy. :booty2:
dave1003
Re: No boost
Post by dave1003 »
i have done all of that ...excellent site bay the way(3800supercharger.net)
i cannot get a reading except OL
Does that mean infinite resistance
Re: No boost
Yes, or otherwise known as an open circuit.
willwren
Re: No boost
Post by willwren »
You won't get boost in park or neutral. So opening the throttle isn't a valid troubleshooting step.
If your actuator gets full travel when you 'trick it' as described in my website, and the solenoid reads OL, replace the solenoid.
dave1003
Re: No boost
Post by dave1003 »
new solenoid fixed the boost problem....what a cool car
thanks for all the help
willwren
Re: No boost
Post by willwren »
Any time, any place. We live to boost.
Re: No boost
Boost is fun, I remember when the Chicken ate a pulley and lost the belt. It sucks not being blown.
