Product Suggestions
brownbrentm
Year and Trim: 2000 Pontiac Bonneville SE
2009 Ford Escape
Product Suggestions
Post by brownbrentm »
Ok, so I want my car to sparkle this summer. This is the first really decent looking car I have owned in a LONG time
I have used the the meguiars(sp?) 3 step process, but I have never been overly impressed with the results. :helpsmilie: :helpsmilie:
So I want my car to look good this summer, without breaking the bank. So if you could recommend some decently priced products that would be great. I have have no qualms with using a little elbow grease, and I am will to take the time to make it look right.
And I have no dedication to any company. So I am open to any products, but I would like to keep the total cost under $50 at most $75
thanks in advance! :hail: :bwoohoo:
Fault lies with the man low enough to lay blame.
crash93ssei
Re: Product Suggestions
Post by crash93ssei »
Reality is that unless you want to drop about $200 - $250 on a professional machine polisher and some good polishes, you really won't get much better then what you were using before. You could try some Meguiar's Swirl X and / or Meguiar's Scratch X, but even then likely the most you will be able to achieve is just breaking the oxidation on the surface of the clear coat. I did scratch x on a two door neon once... my arms were absolutely dead when I was done and the results just were not worth all the work.
yourgrandma
Year and Trim: '02 SSEi
Post by yourgrandma »
100% correct. You cant get correction by hand.
:stupid: x2. An Orbital polisher will blow your mind when you're done, but it's a decent investement. I have around $250 in my setup.
laxmangl
Post by laxmangl »
What those knuckleheads said is 100% true. I have the same set up as Ed and have done several cars with awesome results after spending around 250 for my setup.
If you want to just stick with hand products Maguires is probably my favorite for the price.
brownbrentm
2009 Ford Escape
What brand orbitals do you all have? And what are specs on them for comparison?
Thanks for the responses
01bonneSC
Year and Trim: 05 Chevy 'Hoe
89 SkiDoo
Post by 01bonneSC »
Id find a very reputable body shop/detailer and just have them do the polishing.
Clay barring does wonders also.
brownbrentm
2009 Ford Escape
Now out of curiosity what type of setups do you all have? I have been looking at orbitals and I cant find one more than $75 let alone $250
01bonneSC
89 SkiDoo
Post by 01bonneSC »
Have you ever ran a polisher? Biggest concerns are burning through the clear.
crash93ssei
No worries about burning through the paint with an orbital. About the most trusted out there is the porter cable 7424 xp.
I use and highly recommend Menzerna polishes, you can find everything you need from http://www.autogeek.net they also have a great forum if you would like to check it out.
As far as having a body shop do the work for you.... if you are into keeping your car clean yourself don't pay someone else to do it. You will pay the same money, only have it done once, and if it don't live up to your expectations too bad. If you buy the stuff you will have enough polish and pads to last several years and dozens of details.
Not with an orbital, that's a rotary buffer that you run that risk. Your biggest risk with an orbital is dropping it and denting or scratching the panel.
I run the Porter Cable 7424XP with Lake Country 5.5" pads: http://www.autogeek.net/dual-action-polishers.html
