2000 SE - Cutting out - UPDATED
Alabass
Year and Trim: 2000 SE
Post by Alabass »
Got the starter problem fixed on my wife's 2000 SE but still have a gremlin in the system somewhere. Car has about 125k miles on it. Sometimes around 1500 rpm's the car will cut out, missfire, buck, stumble, whatever you want to call it. I've checked the electrical connections, especially around the battery and the floor pan. I've also visually checked the vacuum lines, plug wires, fuses and anything else I could see. I've also cleaned the MAF sensor. I have a scanner and it's not throwing any codes. I could use some help determining what the problem is. Thanks.
Pontiacdad
Re: 2000 SE - Cutting out
Post by Pontiacdad »
More often then not this turns out to be a spark issue.
You mention you visually checked the spark plugs and spark plug wires.
Did you check the wires with an ohm meter?
How old are the plugs and what is the gap?
Bone Evil
Mods: Tog Headers, cat delete, Al 104's gapped .050, 1.9 rockers, 105 springs,
Intense FWI, DHP Power Programmer PCM, Intense tranny with gen2 lsd,
Aeroforce scan gauge, Clear front and back, N* TB & LQ4 Maf,
Hoosier slicks, ZillaMotorsports P/P GenV & LIM
Pisco_Paul wrote:Every time you pat my head, you pat a piece of my valve retainers.
Alabass
Post by Alabass »
Now that you mention it, it has been probably 60k miles since I put new plugs and wires on it. I'll install a set this week and see if that helps.
SingsCountry1967
Location: North of Buffalo, NY __Been there, done that, got the t-shirts
Post by SingsCountry1967 »
also...when my MAF sensor went bad, it bucked for nearly a month before it threw a code. when these things happen, the best thing is to methodically eliminate each possibility. Starting with plugs/wires is a great choice. :wink:
'00 SLE Maple Red -"Crisis Management" - (125k)- Customized in Silver... Driven with Excitement. RIP 2013 the Crisis is Over
Plugs/wires @ 51k, UIM/LIM gasket @ 59k. Ignition Ctrl Modual @ 109k '04 Monte Carlo SS - "Dream Chaser" - 3.8L SII - (82k miles)...Purchased 8-7-08...Still Driving!
JBMark33
Post by JBMark33 »
Mine was doing this, after replacing my plugs, wires and fuel filter all is well now.
Current: '12 Audi S4 Quattro Prestige 6MT
Previous: '06 Audi S4 Quattro 6MT (for sale!)
'06 Chevy Cobalt SS, Stage II: 2.0L Supercharged, 16psi boost, G85 Package; Recaro Racing Seats, Limited Slip Differential, 5 Speed Manual
'00 Pontiac Bonneville SE ( 4 years, 197,000 miles)
'99 Dodge Intrepid ES (1 year, 2 engines)
'95 Chevy Lumina (2 years, 164,000 miles)
Alabass
Post by Alabass »
What plugs and wires do you guys recommend?
JBMark33
Post by JBMark33 »
For plugs, I would use ACDelco Iridium plugs which are manufactured by NGK. Wires, I used what the parts place supplied me with.
Alabass
Post by Alabass »
Ok guys, finally got around to replacing the plugs and wires, cleaned the MAF and replaced the bad O2 sensor. Not throwing any codes now but still cutting out. My wife said it died on her twice today, once while sitting at a light and the other time while slowing down to stop. The car idles fine, not losing any coolant, oil and transmission fluid are normal. Where do I go from here? TPS?
