Pure Evil is getting LOUDER
bobtaz13
Year and Trim: 2001 SSEi
1991 SE
Post by bobtaz13 »
I have been working on Pure Evil for about three weeks now and Haro just talk me into showing the progress that I have made.
Step one: Gut the interior
Step two: Dynamat
Step three: Get a replacement door panel from Haro and try this.
Ok so you might ask how I did this, well took two pieces of MDF cut out the size of the new speaker. I put a handle on one, then screwed the together with the door panel between them. I used a heat gun to make the plastic backing on the door panel just soft enough to move to where I wanted them, and then slowly took the heat off.
2001 SSEi | Galaxy Silver | GenV supercharger P&P | Intense 3.2 MPS | Intense FWI 4"| Custom PCM | TOG Ceramic headers | Magnaflow 3" cat | 180° stat | Aeroforce scan gauge | PRJ plug wires | PRJ fuel rails | Silicone vacuum lines| AP103 plugs | 3.2 MPS | 42.5# injectors | Intense 1x cam kit | YT 1.8 Rockers | 105# springs | Meziere HD pump | N* Tb | 185mm MAF | 2" Phenolic Intercooler | Oil pressure kit | L32 short block | 5% overdrive SFI Balancer | L67 heads custom ported | EBC USR Rotors | EBC Red stuff pads | Custom HID Fog lights, with HI-beam over ride | Polyurethane motor mount | Energy Suspension end links | GXP Shocks/Struts | Custom Drop springs Front, Rear FE5 Springs | GXP Strut tower Brace | GP GXP 18x8 Rims | Polished Exhaust tips | Triple Edge High Performance Street/Strip 4T65E-HD |
bobtaz13
1991 SE
Re: Pure Evil is getting LOUDER
Post by bobtaz13 »
Here is the setup I am planning
Kenwood DNX9960 7” Navigation head unit
Rockford Fosgate (RF) old school 1100a2 (sub)
RF old school 800a4 (Hi/mid)
RF 10 Farad capacitor
RF T2D212 12” sub
Hertz Hi-Energy HSK163 3 way Components 6 ½ speakers for the front Door
Hertz Hi-Energy HSK165 XL 2 way Components 6 ½ speaker for the Rear Door
Pioneer AVG-VDP1 (advance vehicle Processor) just because I have it laying around
Pioneer 6 ½ touch screen LCD to control the AVP
Also working on front and rear Inferred cameras
Looks great! And that engineering on the door panel is pretty amazing
dpnewfie
Post by dpnewfie »
Nice work! I like the engineering on the door panels as well. =D>
J Wikoff wrote:It has been an honor and privilage to have been serviced by you.
2005 Bonneville GXP, 200k and SOLD!
99bonnieSE
Year and Trim: 1994 K1500 Silverado
Post by 99bonnieSE »
looks awesome. LOVE these sound threads!
It's been a very long time, but, I am still around!
bobtaz13
1991 SE
Post by bobtaz13 »
Had some time to work on the car today. I decided to run the speaker wire for the rear doors. Here’s a trick that i found on line.
Before
After
And here is the first sub box design, not sure if I like it or not, but it will be nice enough to test.
bobtaz13
1991 SE
Post by bobtaz13 »
Here are some pics of today’s progress.
I wanted to keep my 12 awg. stereo wire all the way and not use the factory wire so this is how I ran them to the rear doors.
Since my back has been acting up I decided to pull the dash to run the speaker wires to the front doors.
I got the door dynamated, not my best job but i was trying to use a little as i could so i would have enuff
Shae
Year and Trim: 1992 Bonneville SSEi
Post by Shae »
I would love to see more pics when you have them! /as you make progress :D
M.E.C.P. Certified Installer
bobtaz13
1991 SE
Post by bobtaz13 »
I have been working more on this, but sence this post has so manny pics already here is the link to my Photobucket http://s57.photobucket.com/albums/g224/bobtaz13/. I you have question please let me know
Shae
Post by Shae »
Awesome, I am going to look through your album, Im mainly looking for ideas, In the next few months Im going to start building my system.
99bonnieSE
That car is gonna sound MAD clean. man i'm real impressed with what your doing.
bobtaz13
1991 SE
Post by bobtaz13 »
More pics added, got the battery wires installed and working on the amp mounts.
John Deere Boy
Year and Trim: 1993 SSE
Member since Nov 2003
Post by John Deere Boy »
Holy cow!
PossessedPower
Year and Trim: 1993 ssei,2000 chev venture LE,1990 Dodge d-150
Post by PossessedPower »
nice and clean and savin money they way i like it
sweet job!
More dangerous then a fire in a nursing home..
BFF_Larry
Year and Trim: 95 bonneville sse
Post by BFF_Larry »
T2... dang!
95 bonny sse WALLED.
-new build in progress-
Iraggi HO alt - 320 amp (added "sense" wire and 5k pot, 15.4v)
2 DC Level 5 18s
Cactus Sounds K12
4 runs of 1/0
14 batts.
Mtx 4244 and (2) kicker ix404
YouTube.com/user/pitchdarkshadow
psburtis
Year and Trim: 1995 Caprice SS
Post by psburtis »
that's awesome! i'm really interested in what you did to those door panels. did the heat gun allow you to round out the edges around the speakers so it looks factory? i'm thinking about adding larger speakers to my doors but want to make it look like they were supposed to be there and not just screwed into the door panel....
1996 SE - RIP 7/11/12
1995 Caprice SS - Functional Ram Air hood, 373 auburn posi, Bbk 52 mm throttle body, Cold air intake, B&m ratchet shifter, Built tranny, Leather interior, Hyper tech tune
bobtaz13
1991 SE
Post by bobtaz13 »
that is exactly what i did. If you look at my photo bucket page you should see exactly how to get it done. Be sure to move the heat around alot, or you will over heat in one spot.
97SEBonnevilleMan
Year and Trim: 1997 SE
Post by 97SEBonnevilleMan »
:) Good Job on the install!!! I am glad to see someone tackle it themselves and not pay some shop.How many amps are you running? Do you need a higher amp alternator I think stock is 140 amp. Are you going to put a 1 farad Capacitor Street Wires $119.00 ....Crutchfield.com"to keep your lights from dimming "a good idea for most setups.....Matt
bobtaz13
1991 SE
Post by bobtaz13 »
RF T2D212 12” sub
I also got a 200amp alternator for Powermaster.
I am slowly getting buttoned up, I had knee surgery on the 24th of May so it’s keeping me tied up right now. But I hope to get some more pics up tomorrow…
bobtaz13
1991 SE
Post by bobtaz13 »
Well she's back together. Not a 100% but it runs, drive, and is WAY TOO LOUD. I thought this was going to be a nice clean system and loud enough. But i am blown away at the output of this system. The hi's are so so clean, the mid's are great, and the sub WOW.
I just got my 4th rear view camera, this one looks like it will work. I am a little picky on my camera's. Next is to strap down the sub and finish the trunk off.
Ya about the hi output alternator, cap, and wires. I see less then 0.1v drop when at very hi volume. So that system is work very well.
Pics will be coming soon
