magnivox fireing order
swiles
Year and Trim: 1992 se
Post by swiles »
i have the magnivox coils and i need to know the firing ored for it
1992 bonneville se
bill buttermore
Re: magnivox fireing order
Post by bill buttermore »
If you mean what wires go on what coil posts, I think the above image is for the Magnavox coils and if you look closely, you can see molded into plastic, cylinder numbers beside the posts.
They appear to be arranged as shown below viewed from the passenger side fender:
....6....2....4
..3....5....1
1998 3.8 Dodge Caravan 214K
2000 3.3 Dodge Caravan 175K
willwren
Post by willwren »
And as you face the engine, your cylinder numbers are left to right across the front (near the radiator) 1, 3, 5. Left to right from the alternator to the throttle on the rear is 2, 4, 6.
