How is Camber Adjusted on the Front of Our Cars?
2.3 turbocoupe
Post by 2.3 turbocoupe »
It appears the bolt holes for the top strut mount are not elongated. I did a search and could not find any details on how to adjust camber, other than a mention of elongating the bolt holes. Seems kind of radical - is that the only way?
2005 GXP Silver, Gutted Airbox, K&N filter, 14.61 @ 94.31 mph.
1987 t-bird 2.3 turbo, stock motor with home-ported head, big turbo, big exhaust, alky injection, a bunch of other little stuff, 13.65 @ 102 on radials.
01bonneSC
Year and Trim: 05 Chevy 'Hoe
89 SkiDoo
Re: How is Camber Adjusted on the Front of Our Cars?
Post by 01bonneSC »
Cam bolt in strut to knuckle mount?
Are you gonna do a DIY alignment? Why are you concerned w/ camber?
2.3 turbocoupe
00Beast wrote:Are you gonna do a DIY alignment??
Possibly.
00Beast wrote:Why are you concerned w/ camber?
Tire wear. Since I've owned the car, the outside front tires are wearing out way before the inside. I don't think there is anything wrong with the car - if grandma was driving it I bet the tires would wear evenly, but I often take corners aggressively.
dpnewfie
Post by dpnewfie »
Mine wear like this as well. Might be different with a new alignment. We will see on this next set.
J Wikoff wrote:It has been an honor and privilage to have been serviced by you.
2005 Bonneville GXP, 200k and SOLD!
2.3 turbocoupe
This time around I ended up getting tires that can be run with either side on the outside of the car, so that should allow me to mitigate the problem of uneven tire wear. But I think that adding 1/2 to 1 degree of negative camber ought to further extend tire life, and help the handling as well.
I have been doing my own alignments since around 1998. Not because I want to, but because amazingly that was the only way I could get it done right. Heck I had 2 alignments done on my Tbird to fix a tire wear problem that I reported both times. Then after the problem continued, I found that there were factory rivets in place on the strut towers. They had never adjusted the camber! So I was paying $50 for them to put the car up on a fancy alignment rack and set the toe. Great. Also I found at the time they just wanted to set it to factory spec, regardless of any special request on your part.
I've not touched one of these 2000+ Bonnies though. Apparently, very little is known about what is adjustable or how. I'm going to do some homework before I dive into it, or even let a shop touch it (unlikely).
01bonneSC
89 SkiDoo
Post by 01bonneSC »
Related Parts
2001 PONTIAC BONNEVILLE 3.8L 231cid V6 FI Supercharged (1) OHV : Suspension : Alignment Kit Wiki Price
AUTO EXTRA Part # AXK928 Alignment Camber Kit
W/ SLOTTED STRUT BRACKET; PROVIDES UP TO 1 1/4 DEGREES CAMBER CHANGE; Front (Only 10 Remaining)
$7.20
Add to Cart
MEVOTECH Part # MK928 Alignment Camber Kit
Alignment kits from RockAuto.....
01bonneSC
89 SkiDoo
Post by 01bonneSC »
For yours......
Related Parts
2005 PONTIAC BONNEVILLE GXP 4.6L 281cid V8 FI (Y) DOHC : Suspension : Alignment Kit Wiki Price
$7.20
Add to Cart
$8.23
Add to Cart
2.3 turbocoupe
Thanks. I also noticed that there are bolts available to adjust camber as well:
http://www.autopartswarehouse.com/detai ... 90476.html
01bonneSC
89 SkiDoo
Post by 01bonneSC »
2.3 turbocoupe wrote:Thanks. I also noticed that there are bolts available to adjust camber as well:
Thats what the alignment kit is, and its much much cheaper from http://www.rockauto.com
