performance parts
3.8bonnevillese
- LE Member
- Year and Trim: 2001 SE
performance parts
ok i can't really find any performance parts for my 2001 pontiac bonnevile se i have $650 for the time being to spend i was wondering what i should get to help get my car to a higher hp and faster acceleration
3.8bonnevillese
- LE Member
Re: performance parts
BUMP?
- necropentance
- Year and Trim: 2000 SSEi
you should look under the performance section in these forums there is also a links page with all kinds of websites that have products for anything you could ever need. (FYI most anything that fits a grand prix gtp will work for you some mild modding may be required)
Think for yourself question authority.
Car club I belong to http://www.clublethalinjection.net
GP club that has all 3800's for the Minnesota and surrounding areas http://mnclubgp.com/forum/index3.php
- J Wikoff
- Year and Trim: 1992 SSE
A 2:30 am post with a 2:41 am bump? lol
With $650, you can do a fenderwell intake and a tune and have some cash left, I think. That would be a nice pick me up. Stretch that $650 to $750-$800 and you could add higher ratio roller rockers for a good bit more power.
- harofreak00
You could get into a top swap kit for $650.
- 95naSTA
- Year and Trim: 95 SLE
Used parts all the way. You could get a used set of headers, ER rockers, and a home made intake for 650.
ZZP ER ratio rockers are the optimum ratio rocker for NA cars.
Look here and on other 3800 forms in the classifieds.
Two good sources for new parts are http://www.intense-racing.com and http://www.zzperformance.com
First good mods, however, will be to make sure your car is in perfect running order, especially the N/A. Have you replaced the Upper Plenum and Lower Intake Gaskets? Here's my full maintenance list:
- 1987-2005 Bonneville / Buick 3800 Maintenance List
Run Seafoam through gasoline and intake every 5,000 miles. One pint of Seafoam in a half tank of fuel is a good mix. The intake is optional, but recommended.
Grease: Ball Joints, Tie Rods Every 8-10k ( Green Grease recommended)
Air Filter Every 15k (Amsoil EaA, Purolator PureONE)
PCV Valve Every 30k
MAF Sensor Element Cleaning/TB Cleaning Every 50k viewtopic.php?f=48&t=1661
Fuel Filter Every 15-25k (Purolator, AC Delco, WIX)
Spark Plugs Every 30-50k (NGK TR55 or Autolite 605) (Never Bosch)
Ignition Wires Every 30-50k (Napa Belden, AC Delco, Autolite Pro, NGK) (Never Taylor or Bosch)
Oil & Filter Every 5-6k or Every 6 months (Mobil1 or Amsoil)(Mobil1, Purolator PureONE, Amsoil EaO or WIX) (Never Fram) viewtopic.php?f=45&t=214
*Conventional Oil Every 3k/3 months(Pennzoil with a WIX (Napa), Delco or Purolator filter)
Transmission Flush or Pan Drop Every 15-20k (Always make sure filter is changed when flushed) http://www.pontiacbonnevilleclub.com/fo ... 45&t=10193
Cooling System Flush Every 25-50k or 3-5 Years (Peak or Prestone Green Coolant Only) (Never Dexcool)
Oxygen Sensor Every 80-100k (30k for non-heated) (AC Delco or Denso) (Absolutely never Bosch) viewtopic.php?f=48&t=794
Accessory Belt Inspect every 15k, replace every 100k, or as needed
Cabin Air Filter Inspect and Replace every 15k, or as needed in dusty conditions. (Note: 00+ Only)
Evap Core Cleaning Whenever Needed (Note: 99 and older only) viewtopic.php?f=45&t=2432
*Special Considerations*
All 3800s, LG3, LN3, L27, L36, L26, L67 & L32, especially important on vehicles factory installed with orange Havoline Dexcool Antifreeze/Coolant: http://www.dex-cool.net/
Lower Intake Manifold Gasket Replacement, every 80-100k (ignorance of this can allow coolant to enter your engine oil, this happening can cause irreversible lower engine damage, requiring replacement of subject engine)
Series II, Naturally Aspirated, RPO:L36:
Upper Intake Manifold Plenum Replacement, Every 80-100k (ignorance of this can allow coolant to enter your intake manifold, possible damage to occur can be hydrolock, irreversible damage to emissions devices, misfires, etc. Most times, engine replacement is required if ignored long enough.) viewtopic.php?f=53&t=1061
Series I, II, III RPO Code L67 & L32:
Change Supercharger Oil; Every 30-50k. (Intense Racing or GM Dealer) viewtopic.php?f=56&t=1690
Supercharger Belt; Inspect Every 15k, Replace Every 100k or as needed.
