3.8l question
TUFFBONNEVILLE
Year and Trim: 95 sle
3.8l question
Post by TUFFBONNEVILLE »
what s the differance between fwd 3.8l series 1
and the 3.8l rwd in the firebirds and camaros 93 and up
can anything be swapped and if so what can be
thanks
tuffguyracing.com
83 regal 468 big block chevy
02 gmc k2500 6'' lift kit 35'' tall tires 148,000 miles original drive train
95 bonneville sle stock 230,000 miles original engine one trans rebuilt
95 bonneville ssei 163,123 miles rebuilt engine (mean green bonne) sold
95 chevy suburban k1500 203,000 miles wifes truck sold
01 ford f350 crew cab long bed 7.3l diesel 160,000
J Wikoff
Re: 3.8l question
Post by J Wikoff »
I didn't think F-bodies got the 3800 until Series II..?
Holden had RWD versions. They had a different upper intake, and I think a different bellhousing bolt pattern.
TUFFBONNEVILLE
Re: 3.8l question
your right series II
thanks
tuffguyracing.com
Marik_bathory
Year and Trim: 2001 Grand Prix GT Auto-X
Re: 3.8l question
Post by Marik_bathory »
the only part i know of that is usually swapped is the valve covers. the F-body 3800's have aluminum covers that do not trap heat as badly.
1993 Buick Le Sabre Limited "The Beast"
1998 Pontiac Bonneville SE "The ACG Racecar"
Funded by http://www.AClockworkGarage.com
dpcookson
Year and Trim: 1982 Chevy S10
2003 Ford Focus
1996 VW Jetta
Re: 3.8l question
Post by dpcookson »
The starter is on the opposite side.
Dale
