Transmission Mount Options
Schweet97Z
- Year and Trim: 2002 Silver SSEi
Long story short, the motor rocks towards the firewall and the front mount on the drivers side lifts alot. Is there an alternative mount available (solid, or polyurethane) that will take place of a stock replacement?
2002 Silver Bonneville SSEi
JMB FWI, 180* Stat, Dyno Tune
1999 Bright Platinum Metallic Jeep Grand Cherokee Limited
Tow Machine
2004 Black Limited Edition Banshee
Flotek Ported Cylinders, Milled Head, Lightened Flywheel, Shift Star Mod, EBC Clutch, Toomey T-5's, +6 Swinger
Tow Machine
Re: Transmission Mount Options
Here's a good thread on it:
viewtopic.php?f=18&t=12632&p=134100&hil ... t+#p134100
Just do a search for Solid Front Mount on here and you'll find a ton of hits.
EDIT: Here's the thread I was looking for! viewtopic.php?f=18&t=4000&p=42044&hilit ... unt#p42044
- J Wikoff
- Year and Trim: 1992 SSE
I contacted West Coast Fiero a while back about tranny mounts. They already do custom length rear dogbone mounts, and they have a mount that fits a Fiero with a 4T60/65. So they've already got half the work done on a custom front mount. They just need a stock mount to finish the other half.
