Honey comb?
- dave1764
- SSEi Member
- Year and Trim: 1998 SSEi all black
Honey comb?
Is there any good things that come from taking the honey comb out of the throttle body? Someone said that it would help air intake?
1998 ssei all black 60,000 miles on engine 130,000 on frame
20% tint all the way around. Chrome T-stars, cleared corners
bonnevillain
- Year and Trim: 2002 SLE
Re: Honey comb?
it's proven to be not restrictive up to 450HP or so, and your idle quality will suffer greatly if you do (go ahead and try it, i did. my idle was horrible.)
the screen is there to keep the air flow smooth and constant so the MAF sensor can read the air properly... taking it out reduces the ability of the sensor to do so.
it's not worth it.
it's not worth it.
- Pontiacdad
- Retired Gearhead
- Year and Trim: 2000 SSEi
Re: Honey comb?
When I had a gutted air box I removed the honeycomb and thought the throttle response was a bit better with no poor idle issues.
However when I moved up to the fwi I was getting a bit of stumble without on hard take offs.
Try it for a few days without and decide for yourself.
Bone Evil
Mods: Tog Headers, cat delete, Al 104's gapped .050, 1.9 rockers, 105 springs,
Intense FWI, DHP Power Programmer PCM, Intense tranny with gen2 lsd,
Aeroforce scan gauge, Clear front and back, N* TB & LQ4 Maf,
Hoosier slicks, ZillaMotorsports P/P GenV & LIM
Pisco_Paul wrote:Every time you pat my head, you pat a piece of my valve retainers.
bonnevillain
Re: Honey comb?
id agree... go ahead and try it, but IMO it wasn't worth any small gain in response for the rough running.
Dirthead Racing
- SSE Member
- Year and Trim: 97 ssei
12.67@103
Re: Honey comb?
http://www.zzperformance.com/grand_prix ... .php?id=32
http://www.zzperformance.com/grand_prix ... .php?id=22
"We learned that MAF screens slow down air considerably and removing them will provide more air increase than a larger TB will at times. This does not always equal more HP because the MAF can read improperly but does make for interesting possibilities"
FWIW
FWIW
- Boreas
- Posts like an L36
- Year and Trim: 1993 SE
1997 SSEi 40th - Location: Chi-Town
Re: Honey comb?
I had an improvement in acceleration but at great cost to fuel economy. I put it back in and its better overall with it in.
Forgot to mention this was done on my 93 SE (L27)
1993 Bonneville SE "Old Ironsides" 244,xxx - Junked.
1996 Bonneville SSEi "Double Trouble" 164,xxx - Stock
1997 Bonneville SSEi 40th "Purple Spaceship" 204,xxx - Aeroforce Interceptor, B&M 70264 Trans Cooler, Intense FWI, High-Flow Feline, non-Bose head unit w/ 5 band, Alpine 6x9's, 3.5 MPS, SD Headers, rear disc brake conversion. Future: 1.9 Rockers
1997 Buick Park Avenue "Blue Floaty Thing" 124,000 - Daily Driver/Winter Beater
- Hans
- Year and Trim: '07 MDX | '13 TL | '06 GTO
Re: Honey comb?
you need a set of snap ring plyers to remove it:
http://www.google.com/search?hl=en&q=sn ... tnG=Search
that is the reccomended tool at least.
- willwren
- Retired Admin
- Year and Trim: .
Re: Honey comb?
You can remove it with a ball point pen.
But I suggest you leave it.
- bs009
- Posts like an LN3
- Year and Trim: 82 GP
Re: Honey comb?
how bad would removing it effect gas mileage?
- BonneMe
Re: Honey comb?
It's restrictive, 450hp or not. I'd love to see the test stating otherwise
But if it's worth it, that's another story.
Depends on your right foot, and how the MAF readings are/aren't affected.bs009 wrote:how bad would removing it effect gas mileage?
- willwren
- Retired Admin
- Year and Trim: .
Re: Honey comb?
Restrictive or not, it's purpose is to make sure the MAF sensor can get an accurate reading. You can flow all you want, but if the sensor is screwy because of disrupted airflow, you'll run like dog meat.
Leave the MAF screen in place.
- spidey3479
- Posts like an L27
- Year and Trim: 2001 SSEI, 2004 SLE
Re: Honey comb?
I tried it and hated the idle. I did not see any real gain in takeoff w/o the sensor. The old girl ran much better after I cleaned the sensor properly, though.
1988 SSE-Gone but not forgotten.
2001 SSEI-304,572 miles, 3.5 Pulley, Intense PCM, Intense FWI Spectre filter, 160 tstat, ngk iridiums, belden wires, Silverstars-high and low beam, rebuilt tranny, shift kit, cooler, Dex VI fluid, replace the rear compressor and lines and level sensor, Monroe air shocks in back, FE5 struts and Moog strut mounts, Moog stabilizer bars, AC\Delco control arms.
2004 SLE-Stock, 195,000 miles,oldest son's baby now
2000 Ford Ranger-Stock, 352,000 hard, pizza delivery miles, new control arms (upper and lower), new(used) tranny
