Stock Pushrod Qusetion
Posted: Thu Jun 12, 2008 10:50 pm
by y2kssei
Are stock pushrods from a 2000 Pontiac Bonneville L67 all same lenght? A mechanic at work was going to order new stock pushrods for me but he said they come in two different sizes for my model year. Anyone know if this is true? Thanks for the help!
Re: Stock Pushrod Qusetion
Posted: Thu Jun 12, 2008 11:05 pm
by Archon
I show all 12 push rods as having the same part number. 24504406
Posted: Thu Jun 12, 2008 11:59 pm
by bonnevillain
maybe he meant supercharged and non supercharged? then again those might be the same too..
Posted: Fri Jun 13, 2008 12:08 am
by agrazela
All L36 / L67 / L26 / L32 intake and exhaust pushrods are exactly the same.
How much will a whole set of brand new pushrods run you? And why do you need new pushrods?
Posted: Fri Jun 13, 2008 12:25 am
by y2kssei
I need new pushrods because some pushrod ball tips are warn out and I found two pushrods that were slightly bent. Probably from the 1.9 modiified rockers I ran for the last 35K miles. When the mechanic tryed to place a order, two different length pushrods came up, one was 7.02 and the orther was a longer length, i forgot the exact specs.
Posted: Fri Jun 13, 2008 12:35 am
by Pontiacdad
You should really be running the modified oil restricted push rods rather than stock ones with the higher ratio rockers.
