Stock Pushrod Qusetion
Are stock pushrods from a 2000 Pontiac Bonneville L67 all same lenght? A mechanic at work was going to order new stock pushrods for me but he said they come in two different sizes for my model year. Anyone know if this is true? Thanks for the help!
- Archon
Re: Stock Pushrod Qusetion
I show all 12 push rods as having the same part number. 24504406
bonnevillain
- Year and Trim: 2002 SLE
maybe he meant supercharged and non supercharged? then again those might be the same too..
- agrazela
- Retired Gearhead
- Year and Trim: 04 Lesabre, Stock
98 Lesabre, Retired - Location: San Diego, CA
All L36 / L67 / L26 / L32 intake and exhaust pushrods are exactly the same.
How much will a whole set of brand new pushrods run you? And why do you need new pushrods?
Bone Stock
Retired
Bone Stock
Retired
I need new pushrods because some pushrod ball tips are warn out and I found two pushrods that were slightly bent. Probably from the 1.9 modiified rockers I ran for the last 35K miles. When the mechanic tryed to place a order, two different length pushrods came up, one was 7.02 and the orther was a longer length, i forgot the exact specs.
- Pontiacdad
- Retired Gearhead
- Year and Trim: 2000 SSEi
You should really be running the modified oil restricted push rods rather than stock ones with the higher ratio rockers.
Bone Evil
Mods: Tog Headers, cat delete, Al 104's gapped .050, 1.9 rockers, 105 springs,
Intense FWI, DHP Power Programmer PCM, Intense tranny with gen2 lsd,
Aeroforce scan gauge, Clear front and back, N* TB & LQ4 Maf,
Hoosier slicks, ZillaMotorsports P/P GenV & LIM
Pisco_Paul wrote:Every time you pat my head, you pat a piece of my valve retainers.
