Hello Everyone,
Just finished rebuilding my motor. After a lifter failure & subsequent damage, the engine has been rebuilt.
Work done to engine:
New camshaft
New lifters
New pushrods
New timing chain & tensioner
Polished crank
New pistons & rings
New bearings
Cylinders bored 20 over
heads rebuilt, resurfaced
Oil pump rebuild kit installed
New oil pressure sender unit
After running it for about 100miles, the pressure range is between 80-95psi. Consistently about 85psi while cruising. This is running 5-30W oil.
Does this sound too high? could this work above cause a high change in pressure? Can I keep running like this? Prior to the rebuild, 45psi was normally seen.
high oil pressure after engine rebuild
grey3800
- Posts like an LG3
- Year and Trim: 1993 SE L27
-Patrick
Current (work): 1993 SE L27 --- 275,000 miles and counting.
Current (Fun) : 2009 G8 GT; 6-speed manual; 3.45;
Retired(sold): 1988 LE LN3 --- 273,000 miles of fun, Farewell....
DarkShadow
- Posts like an L36
- Year and Trim: 90 SSE / L67 4T65E-HD
Re: high oil pressure after engine rebuild
Gm Specifies a minimum of 60psi at 2000rpm, I constantly maxed out the 80psi oil pressure guage on my old bonneville at cruising speed with a good sending unit. Your high pressure is more than likely a healthy oil pump and a new engine with tight clearances, it will wear in.
90 Pontiac Bonneville SSE Series 2 L67/4T65-E HD [Frankenbonne 2.0] Swap complete, currently whomping on unsuspecting hondas.
85 Chevrolet Celebrity 2.8 2bbl/440T4
02 Ford Explorer XLT 4.0 SOHC/5R55
10 Mercury Milan Premier 3.0 Duratec DOHC/6F35
