blinkers not workin
- lackawanna1701
- SSEi Member
- Year and Trim: 1993 SE
blinkers not workin
Its been raining heay the past few days up here in buffalo. I noticed my blinkers aren't blinking there staying lit... so im guessing its not a fuse? I also lost the blinker arm return after turning a few months back. Possible link? The rear driver tail lens is busted (can't find replacement at junkyards)
- Dutch
- Year and Trim: 1995 Bonneville SSEI 3800 Supercharged V6
Re: blinkers not workin
Check the "flasher" that's located under the dash board...
As far as the link between the lights not flashing and the return not working on the signal arm...not positive, but the turn arm should just be sending the signal to the lights through the turn "flasher"...the "flasher" is what makes the lights blink off and on.
Do you hear "ticking" when you turn your signals on?
Dutch
1995 Bonneville SSEI Supercharged V6 3800 (195,000 miles)
