LIM/UIM torque specs
rockit-man
Year and Trim: 95 Bonneville SLE
Post by rockit-man »
Hello again. Doing a LIM gasket, having a little troubles with torque specs. I torqued the LIM to 89 in/lbs yesterday, and something just didnt seem right with the plastic upper being the same torque. I checked techinfo and it states a value for intake manifold, but does not differentiate between lower and upper. After some more searching I think that 89 in/lbs for the upper and 11 ft/lbs for the lower is what I was looking for. Can anybody verify this for me? Also, since I have allready applied lock tite and torqued the bolts yesterday, do I need to remove all bolts, clean and re- lock-tite all of my bolts, or can I just continue torquing to spec?
Series II, Leather, K&N with a rice pipe, drilled 180' t-stat, aluminum LIM gasket, tinted, custom grill, michlin hydro edge rubber, 200 watt JVC deck, 12" orion with an 800 watt exterminator pushin.
Pontiacdad
Re: LIM/UIM torque specs
Post by Pontiacdad »
You will need to remove, clean, re-apply loc tite once dried.
And yes the lower intake is 11ft/lbs.
Bone Evil
Mods: Tog Headers, cat delete, Al 104's gapped .050, 1.9 rockers, 105 springs,
Intense FWI, DHP Power Programmer PCM, Intense tranny with gen2 lsd,
Aeroforce scan gauge, Clear front and back, N* TB & LQ4 Maf,
Hoosier slicks, ZillaMotorsports P/P GenV & LIM
Pisco_Paul wrote:Every time you pat my head, you pat a piece of my valve retainers.
willwren
Post by willwren »
I'll go clear that up in the Tech article.
rockit-man
Thanx guys.
rockit-man
Ahh, much more gooder Willwren, thank you.
