Same goes for FWI's with Intense vs Thrasher vs gutting the stock box.
Ignition wires- ZZP vs MSD vs stock (ZZP claims on their eBay site that their wires are 5.7 hp over stock and 4 hp over MSD, but i'd say they're a little biased
I correct myself, then an OEM pcm is well-thought and programmed. To the OP you asked for opinion, I gave it.willwren wrote: INTENSE and ZZP PCM's are not junk. They are well-thought and programmed, and are an improvement over stock for the mildly-modded car. Both can be customized. If you have a tuner in your area, go that way if you can, but don't consider either of the above-mentioned PCM's 'Junk'.
Exactly my point. Vendors do the same, your paying for a factory file with 5 changes made to it that take 2 seconds to do. Just zzp adds more fuel and adjusts trans settings into theirs, verse intense; and intense is a major fail, ie. its disables injectors in torque management = chucked piston; which is the first thing to change in a file.00Beast wrote:Do you realize how long it takes to make a factory tune? They have to make it with emissions, mileage, performance and longevity in mind, not absolute power and performance.
You'll have to remove your pcm from the car and use an offboard.2000Silverbullet wrote: If only I had the patience and support to use my DHP properly.
00Beast wrote:Holy old thread!
