Hi Everyone- I tried searching through the threads but wasn't able to find a case identical to mine...
I have a 1999 SLE with 135,000 miles, mostly highway. I have a 12 mile commute to work and I live in Connecticut, so coldish winters. This winter, my car wouldn't go into overdrive during my commute to or from work- it's about 17 minutes of driving. I tried shifting through reverse, neutral, drive, back to reverse a few times before I left to warm up the transmission(?), this worked a couple times. FYI- I'm not very technically abled. Anyway, I was hoping with warmer weather, the transmission would improve, but it hasn't. Unless the temperature is already 60 degrees when I leave, I won't get overdrive. Occasionally, I will get it 10 minutes into the drive. All the other shifts seems fine and I've never had any problems with the transmission. Would a dosage of Lucas help the case or should I take it to a shop? I would appreciate any help.
Thanks
Overdrive Problems
Re: Overdrive Problems
The typical issue is that the splines on the hub for OD shear off, leaving you with a 3 speed and a bunch of metal shavings. It's weird that it occasionally kicks in, though.
jpp355
- Year and Trim: 1999 Pontiac Bonneville SLE
Usually on the drive home, after the temp has risen into the 70s, overdrive isn't a problem. I can't help but think it's something to do with the outside temperature, but that sounds strange. Does anyone recommend Lucas?
94SilverSSEi
68 w/400
YES!! Lucas is amazing I would drop the pan put a new filter and put a Bottle maybe even two in and then fill up with tranny fluid. And the pan drop will alsogive you an idea of what's going on inside your tranny.
Clay
1997.2 40th SLE-138k
1999 GMC Suburban SLT-191k
2005 Escalade 253k-GINA
jpp355
I appreciate the help- I'm going to look into dropping the pan like you suggested and adding a bottle or two of Lucas.
Thanks
Thanks
One bottle of lucas is plenty. Be sure to inspect for any large shavings, or a large amount of shavings.
jpp355
One bottle, got it. I'll look for shavings, if I find some, what would they indicate?
Something broken inside the transmission.
