muffler question
jtate300
Year and Trim: 2003 ssei
muffler question
Post by jtate300 »
i know mufflers dont enhance any performance but im lookiing to get new ones for mine for the sound and looks...do these motors require the mufflers to have back pressure or can they be straight through design? please let me know what you guys think, thanks!
J Wikoff
Re: muffler question
Post by J Wikoff »
They can be straight through without much effect on performance either way.
BonneMe
Post by BonneMe »
No back pressure is good on ANY engine. But opening up the pipe too much can kill flow.
Any of the usual suspects/camaro mufflers we run around here will do you good!
jtate300
Post by jtate300 »
well reason i ask is id like to put the magnaflow muffler part number 14851....they are a straight through design and didnt know if i needed backpressure......plus would they sound funny bc ive heard some v8's with them and they didnt sound bad at all?
willwren
Post by willwren »
You may have an issue with the angle of the tip on that one. I suggest a muffler without tips, and select the tips you want for proper alignment during install. I also strongly suggest keeping your resonator (or putting a larger one in) at the same time with any straight-thru design. Popping and farting on throttle lift is a nasty sound you don't want.
jtate300
Post by jtate300 »
ok so basically its not a good idea to use those then? even if i were to rework that y-pipe in the back before the mufflers....plus you say use a bigger resonator these things are gonna give me a ricer sound arent they?
98Park
Year and Trim: 1998 Buick Park Avenue Ultra F41
Post by 98Park »
Unless you go with the higher end Borla's or something any aftermarket muffler, flowmaster, magnaflow, whatever, WILL break up and sound weird at higher rpms, it's not a v8 and won't sound like one. It's the cold hard truth, so be very careful about what you do to your exhaust, if you're gonna do it for sound only you're probably not gonna be very happy without spending some decent $$.
My $0.02 on v6 exhaust
http://www.cardomain.com/ride/2879377
Bored 3.9L ;) 3.2" MPS, 4" Intense FWI, 1.9 Rockers, L76/L92 springs and retainers, SSAC Headers, Cat delete, 3" from DP to TPs, Super 44's, Flowmaster res, AP104's, 180* stat, 3.5" tensionor, V+, Dynamat false knock elimination
I love being blown!
jtate300
Post by jtate300 »
OK.... so heres my plan....Will, as soon as i seen what you wrote i ran outside and looked at the mufflers and your right, id be better off getting the ones with out tips and putting them in there....plus the big round tips would look goofy since the exit for the bumper is rectangular.. so ill get my own tips and mufflers and mount them up that way.....thanks guys!
