'99 Bonneville, annoying front end rattle...
Bob Dillon
- Retired Gearhead
My '99 has an annoying front end rattle. Right side only. It occurs when driving straight and increases on right turns; on left turns, curiously, it goes away. I popped the wheel off yesterday to see if the brake pads had prematurely worn and saw that they were fine. I also shimmed up the clip that holds the ABS sensor because it seemed a little loose. No ABS or CELs. I didn't see any bright spots where anything was rubbing against the wheel and no score marks, etc. on the wheel. Nothing, hoses, etc. appeared to be out of place.
Does anybody have any experience with such a problem? Thanks.
- sandrock
- Retired Gearhead
Re: '99 Bonneville, annoying front end rattle...
Were the struts recently done? It's possible the strut isn't tight at the mount. I know I had to tighten mine up about a week after putting the struts in because the air impact didn't quite get the nut down far enough.
- Mechanical Mike
- Retired Gearhead
- Year and Trim: 99 SSEi
Did you check for play in the ball joints & tie rod ends?
Was the sway bar end link still in one piece?
2006 Chevy Monte Carlo SS
- Archon
Also check the stabilizer links. They can rattle if they become loose.
- J Wikoff
- Year and Trim: 1992 SSE
Rattles I've found can be affected by turn direction:
Floppy starter bendix
Harmonic balancer (early in failure in my case)
Sway bar links
Other than things I've actually come across, I'd have to look at everything to think what's going into tension or compression during turns and could loosen or get clamped down.
Sway bar links
- dpcookson
- SSE Member
- Year and Trim: 1982 Chevy S10
2003 Ford Focus
1996 VW Jetta - Location: Jarvis, Ontario Canada
LOOSE NUT BEHIND THE WHEEL???
Sorry, couldn't resist.
Dale
Bob Dillon
- Retired Gearhead
A definite possibility.dpcookson wrote:LOOSE NUT BEHIND THE WHEEL???
Thanks, all, I'm gonna tear into again this PM.
crzydmnd72
- Posts like an L36
- Year and Trim: 1999 SLE
Just a thought, are the calipers bouncing around on the bolts? When I did my wife's brakes last week, one caliper had no bushings left and it was floating around on the bolts, but the clunk was random and hard to reproduce consistently
Glenn
1999 SLE 70k Stock for now
- reb
- Posts like an LG3
- Year and Trim: 1997 Bonneville SE 40th Ann Edition
Original Owner - Location: Wantagh, NY
++ check for a broken stabilizer link.
