buzzing noise coming from the rear of the car
screwstonjay713
- Year and Trim: 2003 Bonneville SE
ever since ive had my car i have noticed a buzzing sound coming from the rear of the car at times. Usually it only lasts a few seconds and doesnt seem to affect anything else. at first i thought it was the antenna til i looked and saw there was none lol. but i was just wondering if anyone else has that issue or maybe know what it may be?
2003 bonneville SE "Tha maroon monsta"- Blacked out tail lights..20inch gitano blades..7.5inch jensen headunit..2 kicker cvrs..2000watt boss amp..clear corner headlights..Red interior lighting..More to come...
http://www.cardomain.com/ride/3160291
myspace.com/screwstonjay
- J Wikoff
- Year and Trim: 1992 SSE
Re: buzzing noise coming from the rear of the car
Is it the rear load leveling compressor running? Is it frequent? More often when there's additional weight in the back?
screwstonjay713
most of the time im riding by myself but i have subwoofers in the trunk. it happens usually about 2-3 minutes after the car has been running and it happens sparatically. i recall hearing most often when im sitting at a stoplight or stop sign or if the car is just sitting.
- J Wikoff
If I remember right, all 00+ had rear load leveling, and the compressor is hiding behind the passenger rear tire. Heavy stereo equipment and possibly leaky air struts could make the air pump/compressor run fairly freqently. Try turning the car on, popping the trunk open, and sitting on the back end. See if it makes the same noise after a few minutes.
- WhiteArrow3800
- Moderator / Social Dev
- Year and Trim: ___
2009 Pontiac G8 GT - Location: Williamsburg, Va
IIRC the pump should come on for a couple seconds after the car has been running for about 15 seconds, it does this as a test.
