help with audio system
z28@heart
Year and Trim: 2001 SE
Post by z28@heart »
hey, i'm new to this forum, and i was wondering if there was a way to run subs and an amp with my stock stereo head unit using like a equalizer or something to that affect.
i have a 2001 bonneville, without bose/onstar
help would be so greatly appreciated. thanks
grandprix104
Year and Trim: 2001 SE L36
Re: help with audio system
Post by grandprix104 »
simple. Buy an amplifier with high/speaker-level inputs. Run your power to the battery under the back seat. Run your ground either directly to the battery or a seatbelt bolt(remove any paint first). The remote wire is a little bit trickier. There is a fuse in the box under the back seat that is switched with the ignition. Stick the remote wire in with one of the fuse blades and run an inline fuse on the remote wire. Get your audio signal from the rear speakers in the deck. Use suitcase connectors to avoid cutting the factory wires. Run those new speaker leads to the high-inputs on your amp. You are now up and running. The only downside to this method is that the amp will only turn on when the car is ON. So sitting in the carr with it off you will have music but no subs. Another option is an amp with signal sensing technology. These amps don't require a remote wire, they will sense audio signal whenever the stereo is playing and will turn on automatically. These amps are more rare but a nice option with a technical factory audio system like these bonnevilles have.
2001 Pontiac Bonneville SE 3.8n/a 110k, PLIM, APN UIM, 180 T-stat, Clarion DXZ385USB, Memphis 6.5s/6x9s/12" PR sub, Kicker ZX700.5 Amp.
1999 Jeep Grand Cherokee Limited 4.7 V8 120k, WAAG Brush Guard, 2in Lift, SkyJacker Shocks, HD front driveshaft, Infinity Tweeters, 12" Memphis sub, Rockford Fosgate Punch amp
1994 Pontiac Grand Prix 3100 180k SOLD :(
z28@heart
Post by z28@heart »
so i wouldn't even need an equalizer? i could just run my power shut off out of my fuse and the subs will work with the stock head unit ?
grandprix104
Absolutley! What I suggested above is what I used to have in my car. I have since upgraded to an aftermarket deck for better sound quality, but my old system worked pretty well for what it was.
BTW Welcome to the forum :banana:
z28@heart
Post by z28@heart »
what would be some of those amps with high/speaker level inputs?
and thank you haha
z28@heart
Post by z28@heart »
so we use speaker wires instead of audio cables?
grandprix104
Most amps have speaker level inputs. Just make sure you check specifically for that feature when you are buying.
You just tap into the factory rear speaker's wires and run them to the amp and to the speakers. Now I will say that this will give you a less than optimal signal, BUT for a sub the difference is not very noticable. This is the best option for bang for the buck. My jeep is hooked up this way and sounds great, and as I mentioned, my previous system in the Bonneville was done this way.
If you want to run RCA cables then you will need a new deck which is a PITA to install in these cars (but well worth it).
I will also mention that there are high-to-low level converters if your amp of choice has no speaker level inputs. I would reccomend finding an amp with this feature on board because, the more components you have in the signal chain, the more chance you have of screwing something up or degrading your signal.
z28@heart
Post by z28@heart »
yeah i attempted to hook up a new HU, but it was a bit confusing with the wiring.
grandprix104
If you haven't already seen it, here is my write-up on the HU install process. It really is a pain compared to most cars.
viewtopic.php?f=13&t=7319
z28@heart
Post by z28@heart »
yeah i checked that out, but what i couldn't figure out was why to put the orange red together, because the orange controls the lights so if i hook all that up to it, won't it put a bad strain on my lighting fuse?
grandprix104
I'm not sure I understand you. The "CDI" and the deck's harnesses will both have orange wires for the illumination of the faceplate which will need to be connected. They also will both have red wires for powering the rest of the deck that need connecting. I don't recall ever connecting an orange wire with a red one. The big change I made to the way it is supposed to be hooked up is I added a direct power line from the battery, and that was completely optional (It didn't make any difference power-wise). Other than that you just match up all the colors on both harnesses.
z28@heart
Post by z28@heart »
my harness that came with my HU is missing an orange wire then.., because there is none. so i'm not sure. but i will try just using the stock head unit for awhile atleast.
grandprix104
They may have made it another color. That happens frequently. Some HU may not even have an illumination lead anymore. They often have a dimming control in the HU settings.
z28@heart
Post by z28@heart »
well my red wire from my harness isn't hot, orange is hot, which that didn't make sense to me and my father.
PontiacPrincess
Post by PontiacPrincess »
grandprix104 wrote:simple. Buy an amplifier with high/speaker-level inputs. Run your power to the battery under the back seat. Run your ground either directly to the battery or a seatbelt bolt(remove any paint first). The remote wire is a little bit trickier. There is a fuse in the box under the back seat that is switched with the ignition. Stick the remote wire in with one of the fuse blades and run an inline fuse on the remote wire. Get your audio signal from the rear speakers in the deck. Use suitcase connectors to avoid cutting the factory wires. Run those new speaker leads to the high-inputs on your amp. You are now up and running. The only downside to this method is that the amp will only turn on when the car is ON. So sitting in the carr with it off you will have music but no subs. Another option is an amp with signal sensing technology. These amps don't require a remote wire, they will sense audio signal whenever the stereo is playing and will turn on automatically. These amps are more rare but a nice option with a technical factory audio system like these bonnevilles have.
Exactly what I'm planning to do with the my Sony 12" and my Lightning Audio amp out of my VW I sold. The Lightning Audio amp has a hi level input, so it's all good. I wanted to use my Blaupunkt or Phillips Sound Labs amp, but niether of them have hi level inputs.
I poked around the fuse panel under the seat looking for a switched circuit but couldn't find one. Any Idea which fuse postion?
I thought about putting in a aftermarket stereo, but really I don't want to go through all that trouble. The Bonne is the family car and I just want a little more bottom end out of it. For more boom I go get my Fiero, LOL.
(wifes account. I really need to register here someday)
Edit to add: 2000 Pontiac Bonneville.
Last edited by PontiacPrincess on Fri Feb 12, 2010 6:42 pm, edited 3 times in total.
They say I have A.D.D but I just don't understa......Oh Look! A Kitty!!
la_dyt
Year and Trim: 2001 Pontiac Bonneville SE
Post by la_dyt »
I have a 2001 Bonneville SE with the Same situation. I just installed an amp last night but left the remote off until I find out the Issue. At first, I plugged the remote into the rr defrost and the thing stayed on all the time. So i can tap into the ignition and It would be fine?
Thanks for the Help!
kmalinich
Year and Trim: 1997 SE
Post by kmalinich »
airbag fuse works usually, if its in there.
lewis26
Year and Trim: 2003 SLE || 51k miles
Post by lewis26 »
You dont need a new head unit to use rca's, but rather a line out converter. Then you could run RCA's.
Additionally, for my sub install, I will be using the 12v cig lighter for my remote turn on lead. I am already going to have to run my remote gain control wire through the car to the dash, so an extra wire wont make much difference. This wire will allow my subs to be on any time the radio is on, and also will stay on 10 minutes after the car is off like the radio does. Should work without issue.
-Mike
Won't plugging something in the cig lighter make the sound fuzzy? I thought the cig lighter was a bad place to get switched 12v from? (I could be way off track here).
kmalinich
Post by kmalinich »
00Beast wrote:Won't plugging something in the cig lighter make the sound fuzzy? I thought the cig lighter was a bad place to get switched 12v from? (I could be way off track here).
Only if the wire was very, very poor quality, and it would most likely be alternator whine because the remote line from the cig lighter doesn't have a good ground up front to share with the amp in the back.
And if you're running the wire up front anyway, just splice into the switched 12v line in the radio harness.
