upsizing my Lesabre's tires?
Need For Steve
Year and Trim: 1994 Buick LeSabre Limited
Post by Need For Steve »
the Buick will be getting a new set of rubbers here soon, and i'd like to go with a slightly wider size than the stock 205's. i've been thinking 225 or 235. something to "mean" the stance up a bit, and put a little more rubber on the road. thing is, i'm not quite sure how wide is "too wide" or if a wider size will adversely affect my handling or anything else. anyone have a suggestion for a good tire size to increase the contact patch but not over-do it?
i also can't decide if i wanna stick with white walls and hubcaps, or if i wanna ditch the hubcaps for interceptor style center caps and go with white letters...any opinions? :bhuh:
Last edited by Need For Steve on Thu Feb 04, 2010 12:33 am, edited 1 time in total.
call me Steve...
HAI, full 2.5" exhaust, resonator delete, Pioneer Audio, F17 transaxle, Toyo Versado LX 215/70/15's
willwren
Re: upsizing my Lesabre's tires?
Post by willwren »
We need to know the factory size and width of your wheels.
15"? 16" diameter?
What's the bead-bead width? Is it the same as Bonneville 16's or not? Critical questions to be able to help you.
LeSabreUltra
Post by LeSabreUltra »
Stock LeSabre wheels with hubcaps are 15".
-Dan
_
_
Post by Jrs3800 »
I think they are 205/70-15 stock
If you keep the 15's go with some 215/65-15
If you go up to a 16" I'd say 225/60 16... With these you speedo error may be a tad better than 1 Mph at 60 MPH iirc...
willwren
Post by willwren »
Going to 16" H body wheels, you can go up to 255 (some rubbing possible) or 245 safely (I run these on the Zilla) and I run 235 on the SLEeper.
ChilinMichael
Year and Trim: 2004 Volvo S60
Post by ChilinMichael »
http://www.miata.net/garage/tirecalc.html
Tire size calculator if you decide to up the wheel size, you can use this to calculate how far off (if any) your speedometer will be off.
Need For Steve
Ultra's right, i have the 15" x 6"? steelies. according to that calculator, 235/60/15's would almost match the stock size exactly...sweet
call me Steve...
Except thats not a very popular size at all. Tirerack only shows 3 options available in all-seasons.
Find some cheap 16" rims and put some 225/60R16's on them.
willwren
Post by willwren »
That width is pushing it on 6" wheels.
xX3800Xx
Year and Trim: 1990 Lesabre
1987 Lesabre
Post by xX3800Xx »
215/65/15 would be a fine size. You could also run some 225/60/15. If you go to 16" you can go 225/60/16, 235/55/16, 245/50/16. I have run all of those sizes on my car.
Specification Sidewall Radius Diameter Circumference Revs/Mile Difference
205/70-15 5.6in 13.1in 26.3in 82.6in 767 0.0%
225/60-15 5.3in 12.8in 25.6in 80.5in 787 -2.5%
235/60-15 5.6in 13.1in 26.1in 82.0in 773 -0.7%
215/65-15 5.5in 13.0in 26.0in 81.7in 776 -1.1%
225/60-16 5.3in 13.3in 26.6in 83.7in 757 1.3%
235/55-16 5.1in 13.1in 26.2in 82.2in 770 -0.5%
245/50-16 4.8in 12.8in 25.6in 80.6in 786 -2.5%
spydog
Year and Trim: 1998 and 1999 bonnavelle SLE 1994 bonnavelle SSE
Post by spydog »
i had a set of 235/70r16 on my 1998 sle bonneville
1999 SLE 98,xxx miles
1998 SLE 178,xxx miles sold for $1,400
1994 SSE 289,xxx miles
1993 SSEI 324,xxx miles sold for $500
2002 Trans Am 32,xxx miles
1998 silverado waldoch conversion 122,xxx miles SOLD
1979 Trans Am 68,xxx miles
2000 GMC crew cab long box dually 82xxx miles
willwren
Post by willwren »
Spydog, the topic author has 15" wheels, not 16. And 6" wide at the bead, not 7 like ours.
Need For Steve
so i'm thinking i'm just gonna stick with the stock size, and pay for quality, not just a wider tire.
here are my options. i've never bought tires before and am completely lost lol. what do you guys recommend for a good all season/summer tire? usual driving conditions are summer and rain, my car hardly ever sees snow...
http://www.tirerack.com/tires/TireSearc ... ireIndex=0
**sorry about the thread-whoring lol. didn't know if this would completely randomize the topic of this thread or not**
Last edited by Need For Steve on Fri Feb 05, 2010 12:17 pm, edited 1 time in total.
call me Steve...
repinS
Moderator
Moderator
Year and Trim: 09 G8 GT
Post by repinS »
spydog wrote:i had a set of 235/70r16 on my 1998 sle bonneville
That's a way wrong tire size to run on a Bonneville. :eek2:
How much are you looking to spend, Steve?
Need For Steve
repinS, i'm not lookin' to spend no more than $500 for the set, mounted and balanced. the two i've liked most so far are Pirelli P4's and a set of Michelins...
call me Steve...
repinS
Moderator
Moderator
Post by repinS »
The P4 sound like a good bet. Yokohama Avid TRZ might be another option, they're cheaper. Buddy has a set on his Camry, VERY quiet and the traction is decent.
Which Michelin?
Post by Jrs3800 »
Need For Steve wrote:so i'm thinking i'm just gonna stick with the stock size, and pay for quality, not just a wider tire.
Get the 215 65 R15
This size will be the best mix of both worlds :wink:
LeSabre in Buffalo
Year and Trim: 2012 Eco
Post by LeSabre in Buffalo »
Need For Steve wrote:repinS, i'm not lookin' to spend no more than $500 for the set, mounted and balanced. the two i've liked most so far are Pirelli P4's and a set of Michelins...
I've had a set of Pirelli P4's in 205/70-15 on my car for the past ~40k miles. LOVE them! They grip very well in the dry, and equally as well in the wet. They have good snow traction for an all-season, as I found out when in Buffalo, NY over Christmas the past few years. The handling is very good, much better than cheaper all-seasons. They're about half-worn right now, so I figure on a 60-70k mile lifespan. They're sensitive to air pressure, and get very mushy and squirmy at less than 35 PSI. They are also fairly noisy, but I like the tires telling me how wet/dry the road is.
