91 s-10 needs help
TUFFBONNEVILLE
Year and Trim: 95 sle
91 s-10 needs help
Post by TUFFBONNEVILLE »
this truck is my brother-in-laws it a 91 s-10 4.3l with 147,124 the problem is it wont stay running at idle it just dies also when your driving it has no power just stumbles and falls flat on its face when floored if you give a 1/4 gas its ok but still has the stumble. i have changed map sensor,tps sensor,egr valve,rebuilt tbi unit, intake gasket,plugs,wires,cap,rotor, the cat is newer maybe 3 or 4 years old. the only thing i can think of is the timming chain has slop in it and dont want to stay running. any ideas would hlep me. thanks
tuffguyracing.com
83 regal 468 big block chevy
02 gmc k2500 6'' lift kit 35'' tall tires 148,000 miles original drive train
95 bonneville sle stock 230,000 miles original engine one trans rebuilt
95 bonneville ssei 163,123 miles rebuilt engine (mean green bonne) sold
95 chevy suburban k1500 203,000 miles wifes truck sold
01 ford f350 crew cab long bed 7.3l diesel 160,000
J Wikoff
Re: 91 s-10 needs help
Post by J Wikoff »
Have you checked for big vacuum leaks? Do you have a real-time data scanner to see what the fuel trims are doing? Does it have MAF sensor?
BlackHawk99
Senior Moderator
Senior Moderator
Year and Trim: _
Post by BlackHawk99 »
What are the fuel pressures? Age of the pump? Age of the pressure regulator?
TUFFBONNEVILLE
no vacuum leaks and i have a snap on scanner mt2500
it does not have a maf sensor.
for the fuel pump could be oem have know idea. the fuel pressure regulator a few months ago.
and how do you check for fuel pressure their is no valve to tap into
tuffguyracing.com
J Wikoff
Post by J Wikoff »
There isn't a pressure port anywhere?
Can you scan to see if it's really lean or rich at idle? Or maybe pull a plug or two and "read" them.
TUFFBONNEVILLE
im at work so when i get home ill check it out
thanks
tuffguyracing.com
crash93ssei
Post by crash93ssei »
Was the problem the same before and after changing the pressure regulator? A friend of mine had the same problem and the spring inside the pressure regulator was broken in five pieces.
TUFFBONNEVILLE
yes it was the same before and after changing fuel pressure regulator.
i will scan it when i get to work this afternoon
tuffguyracing.com
TUFFBONNEVILLE
ok i scan it and i have a code 44 lean exhaust
and i must of broke the coolant temp sensor cause
that code is 15 coolant temp signal high or low
so open the hood and the temp sensor is broke
also the truck was scaning the truck at 191 degrees.
but i leaving out of town tonight and ill be back monday night
thanks
tuffguyracing.com
TUFFBONNEVILLE
so iam back on this project again put new temp sensor in cleared codes
so i scaned it again no codes ill give you the run down what the readings on the scaner was
1) exhaust oxygen was going back and forth lean/rich
2) tps (v) 0.66
3) iac position 43
4) o2 crosscounts on the low side i saw was a 17 and on the high side 23
5) map(hg) 11.0
6) map(v) 1.58
7) coolant temp was around 155 and getting hotter
tuffguyracing.com
xX3800Xx
Year and Trim: 1990 Lesabre
1987 Lesabre
Post by xX3800Xx »
Vacuum looks a little low at idle i would think it would be more around 20. It would appear you have a vacuum leak.
TUFFBONNEVILLE
well took it out for a test drive on lunch and scan it
at 191 temp
tps (v) .056
iac position 43
map(hg) 9.0
map(v) 1.12
o2 crosscounts where going back and forth from 0 to 1
oh and now it kinda stays running at idle only when it warms up and then
the rpm goes up and down like it going to die then the rpms go up and it still acts the same
when you floor it falls flat on it face
Last edited by TUFFBONNEVILLE on Wed Oct 28, 2009 6:56 pm, edited 2 times in total.
tuffguyracing.com
TUFFBONNEVILLE
put all new vacuum lines on and that didn't help
i wish i could test the fuel pressure
tuffguyracing.com
Mopar Man
Year and Trim: 98 Plymouth Grand Voyager
Post by Mopar Man »
Check the fuel filter?
Mister Chambers! Don't get on that ship!
TUFFBONNEVILLE
fuel filter maybe 6 months old
i think its time to drop the tank and put a fuel pump in it to see if that makes
it any better if not my brother in law can pick it up and take it to a shop
tuffguyracing.com
xX3800Xx
1987 Lesabre
Post by xX3800Xx »
TUFFBONNEVILLE wrote:put all new vacuum lines on and that didn't help
What about intake gaskets? Brake booster 1 way checkvalve? modulator for the trans?
throttle body gasket? Bad IAC?
tpulliam79
Year and Trim: 1991 SSE+I. 1994 ssei
Post by tpulliam79 »
the fuel pressure can be tested, you need a tbi fuel pressure tester, I think autozone has them it hooks up between the supply and return lines to the tbi, or you can get a fitting to go where your fuel filter is. kind of a pain but beats replacing a pump if not needed. also did you clean or replace the iac?
1991 SSE+I ( supercharged)
1994 ssei
WCBF '08
TUFFBONNEVILLE
i did clean the iac when i rebuilt the tbi could be bad i guess ill have to unplug it to see if it does anything. also ill check the one way check valve and modulator.thanks for the tip about the fitting at auto zone ill check that out when i get off of work.
tuffguyracing.com
tpulliam79
also have you checked the timing?
1994 ssei
WCBF '08
TUFFBONNEVILLE
i have messed around with it made it run real bad so i just put it back to stock
and i do know about the wire you have to unplug under the pass side of the dash
wont be able to look at it tonight but tomorrow morning ill be lookin at the truck ill let you guy know what i find out. thanks
tuffguyracing.com
