I have a Birdy.....
Icebound
Year and Trim: 1994 SSE White Loaded
1997 SSE White Loaded
I have a Birdy.....
Post by Icebound »
... on the 1997 SSE, there is a birdy at idle.
It takes a few minutes after start-up to warm up, but gets quite notable in the cabin after a few minutes... have to turn the radio well up :)
Apparent suspects are the usual belt-driven accessories on the right side.
My local mechanic was adamant that it was the idler wheel. But replacing it solved nothing.
The Birdy goes away under any engine torque. Even in neutral, it will go away when engine is revved up above idle.
But at idle, or coasting up to a light, etc... it returns.
Nothing seems to be destroying itself, as it has been a year or two.... it probably is not getting any worse, just more annoying as I get older.
Was hoping that perhaps somebody has had something similar....
Re: I have a Birdy.....
Try some belt conditioner, or a new belt. That's always the first step. Also could be the PCV leaking? Check the o-ring on the PCV valve
sonoma_zr2
Year and Trim: 1999 SSEi
1997 SSEi-Resting-353K
Post by sonoma_zr2 »
hit the ribbed side of the belt with some wd-40. dont soak it , just a quick squirt or 2. this will test the belt.
laimisl
Year and Trim: 1997,Green,3.8V6 SeriesII,166k miles.Drild T-stat.
Post by laimisl »
Hi guys,
So does that mean that if WD40 makes the noise go away it is time for the belt to be replaced?
thanks,
Larry
Billha
Year and Trim: 1999 SLE 112,000mi
2002 Park Ave Ultra 88,000mi
Post by Billha »
Yes, if a little squirt of WD40 makes the noise stop for a little while, that belt is the culprit. The belt may look fine (not cracked or frayed) but may make noise anyway.
01bonneSC
Year and Trim: 05 Chevy 'Hoe
89 SkiDoo
Post by 01bonneSC »
Drop the $ for a Gatorback, they ARE the best!!!
Black Pearl
Post by Black Pearl »
gatorbacks are made with hint of awsomeness. I liked my s/c belt so much I bought one for my acc belt BEFORE I needed to replace it
Bonneville Forum COTM Sept. 09
Pontiac Bonneville Club COTM Dec. 09
grandprix104
Year and Trim: 2001 SE L36
Post by grandprix104 »
As unrelated as the PCV suggestion sounds, if its leaking it sounds EXACTLY like a worn out pulley. Just so you know.
2001 Pontiac Bonneville SE 3.8n/a 110k, PLIM, APN UIM, 180 T-stat, Clarion DXZ385USB, Memphis 6.5s/6x9s/12" PR sub, Kicker ZX700.5 Amp.
1999 Jeep Grand Cherokee Limited 4.7 V8 120k, WAAG Brush Guard, 2in Lift, SkyJacker Shocks, HD front driveshaft, Infinity Tweeters, 12" Memphis sub, Rockford Fosgate Punch amp
1994 Pontiac Grand Prix 3100 180k SOLD :(
01bonneSC
89 SkiDoo
Post by 01bonneSC »
Get a mechanics stethescope (one of the best tools ever invented!!!!) and take a listen to all your pulleys for grinding or sounds of bearing failure.
