weird vacum problem after PLIM install
alexcoqui
Year and Trim: 2001 Blue SLE - 2001 Black SSEI - 2005 Grey Aztek
Post by alexcoqui »
After installing the the PLIM last week, the car had been making this noise that I thought was the belt, then a pulley. & now think is a vacum problem.
Let me start by explaining the symptoms. When the car is cold it wont do nothing, then after a few minutes on the road the loud wine will start, but only when Im not accelerating, if Im on a light & the noise is bothering me I rev the car to about 2500 with the brakes on & the noise will stop.
Now the way I discovered that the problem wasnt coming from the pulleys, was that while the car was on I removed the oil cap & the noise stopped, & there is a strong suction in to the oil hole, at the same time when I took the oil cap off, a shake started like when there is a vacum leak. I put the cap back on & the engine is fine again but with the noise.
What did I mess up? Any ideas of where to look?
2001 Blue SLE - 1995 Black SSE - 1988 Black GTA
Re: weird vacum problem after PLIM install
Post by gonzo4191 »
O-ring on your PCV valve ;)
alexcoqui
Post by alexcoqui »
will check on it. thatks
Post by gonzo4191 »
people don't realize that little sucker there, till it starts to whine like yours does now
SuperSLE
Year and Trim: sold
Post by SuperSLE »
I also had a problem with my brake booster hose leaking and making the same noise.
2000 SLE
alexcoqui
Post by alexcoqui »
I dont understand something, do we get more vacume with a PLIM?
alexcoqui
Post by alexcoqui »
Wow, you guys are amazing. Rigth on the money.
grandprix104
Year and Trim: 2001 SE L36
Post by grandprix104 »
Why does this happen? Your problem exactly describes my squeeking belt issue! I have replaced every pulley on the motor and it still squeels everytime it warms up! I took off the oil cap and there was a LOT of suction. After the cap was off the squeel went away immediately.
2001 Pontiac Bonneville SE 3.8n/a 110k, PLIM, APN UIM, 180 T-stat, Clarion DXZ385USB, Memphis 6.5s/6x9s/12" PR sub, Kicker ZX700.5 Amp.
1999 Jeep Grand Cherokee Limited 4.7 V8 120k, WAAG Brush Guard, 2in Lift, SkyJacker Shocks, HD front driveshaft, Infinity Tweeters, 12" Memphis sub, Rockford Fosgate Punch amp
1994 Pontiac Grand Prix 3100 180k SOLD :(
PDXGTP
Year and Trim: 1998 Pontiac Grand Prix GTP
Post by PDXGTP »
The guys with intercoolers will also have the problem until the PCV system will gum up the port hole with oil/coating inside. mine did it, it was a loud whistle and like I said, after a build up it went away.
if you have suction on the oil cap then the PCV valve its self is messed up in one way or the other.. its very common.
Best 60' = 1.716
Best ET = 12.186
Best MPH = 112.98
Post by gonzo4191 »
make sure that o-ring is on the pcv!! :-)
sound like....http://s258.photobucket.com/albums/hh25 ... 0_0651.flv
grandprix104
Anyody got a pic? I saw no o-ring on my PCV. Mine is doing exactly that in the video except it isn't constant. More of a chirp chirp chirp sound to it. There is a TON of suction on the oil cap and the car almost dies when you take it off.
Can anybody explain how suction is produced in the valve cover when there is a leak in the PCV area.
I also need another MAP sensor. Mine is broken into two pieces held together by electrical tape. Anybody have one?
Post by gonzo4191 »
just snapped these for you....
PCV location with MAP sensor on top(I think)
PCV valve with o ring in place
O ring it self
grandprix104
great mine didnt come with a oring. :roll: Thanks for the pic! I see if I can find another map at the junkyard.
Post by gonzo4191 »
your old one had the O-ring you should of transferred over ;)
post up in the wanted section wanting a MAP, someone might have a good one
grandprix104
aw man!
after a $30 AC clutch bearing
$20 belt
$10 aternator main bearing
& $25 idler pulley
my problem was solved by a $0.10 o-ring :angry7:
Post by gonzo4191 »
hey, now you don't have to worry about those parts for a while!!
glad to hear your problem is fixed
