half shaft and ball joint drivers side
irish91983
1992 Bonneville SSEi (Sold)
Post by irish91983 »
Hi All
Today i took a turn and my half shaft just snaped in half and also snaped my ball joint to. I got a new half shaft and new ball joint, my problem is that i have the old ball joint and the old half shaft out but i cant get the bolts out that hold the strut to the hub the nuts are off but bolts are stuck. I have tried to raise the hub to take pressure off and use a all most a whole can of pb blast and still nothing. My question is did i miss some thing some where.
Thanks Keith
2001 SSEi Bumbles
zuper8
Year and Trim: 96 SSEi- 157K
Re: half shaft and ball joint drivers side
Post by zuper8 »
No they just suck sometimes. I had to use an air hammer to get mine to move, and even then they fought.
- Rachael
trf_ssei
Year and Trim: 1998 bonneville SSEi
Post by trf_ssei »
put the nut on and try tapping it with a hammer(dont mushroom the nut) while turning the bolt with a ratchet, worked for me.
Phibes
Year and Trim: 1995 SSE
Post by Phibes »
The bolts are likely gaulded into place with rust. When I replaced my rear air struts, I fought with them, too. A sledge hammer wouldn't budge mine (mine were original from 95). I bought new bolts (I bought them from Advance Auto Parts) and then called my father to bring his hot wrench (torch). We heated them until they finally would tap out with the sledge hammer. You may have to resort to this yourself. Good luck.
-=[]Phibes[]=-
irish91983
Thanks for all the ideas..I know i already need one new bolt from hittin it so many time with the hammer. Im gonna try those ideas today and hopefully get it finally done.
Thanks again
2001 SSEi Bumbles
